By buying this product you get 54 loyalty points
Planar Magnetic Headphone 90dB 8Hz-65kHz 35 Ohm
HiFiMAN offers with the Arya a high-end open circumaural headphone. It is equipped with Planar Magnetic transducers, a speciality of the brand, which allow it to achieve exceptional precision and richness of sound. Its extended frequency response from 8Hz to 65kHz allows you to enjoy the smallest details of high-resolution audio files.
The HiFiMAN Arya is equipped with Planar Magnetic transducers, i.e. speakers composed of a membrane moved thanks to a large film of extremely fine and light conductors. This particular technology allows a larger emissive surface and an excellent reactivity.
The brand also uses an asymmetrical magnetic circuit, using smaller magnets on the side of the membrane facing the ear. This integration prevents sound waves from interfering with each other for unparalleled sound purity.
The loudspeaker grilles, open on the back of each transducer, allow an important reduction of sound reflections, ensuring an incredible opening of the sound scene.
HiFiMAN uses an asymmetrical design for the ear cups of its headphones. This design adapts perfectly to the shape of the ear for optimal comfort, even during prolonged listening. The ear cushions are designed with a micro-ventilated fabric inner face that allows the skin to breathe and leather sides to contain the sound inside the ear cups.
To ensure a perfect fit and above all to offer an excellent comfort of use, the Arya is equipped with a wide leather headband. This allows the weight of the helmet to be perfectly distributed on the head.
The HiFiMAN Arya headphones are connected with a detachable 3.5mm jack cable. Ideal to adapt the cable to your taste but also to promote an excellent durability of the headphones.
The headset comes standard with a 3.5mm jack to 6.35mm jack cable, incorporating copper conductors.
The external design of the Arya uses two materials: high quality metal for excellent strength and high-end plastic to reduce the weight of the helmet.
Product type | Headphone |
Drivers | Planar Magnetic Asymmetric magnetic circuit |
Headphone type | Open back |
Coupling | Circumaural |
Material | Arch : Metal Headband : Leather Ear cups : Fabric / Leather |
Sensitiivity | 90dB @ 1kHz, 1mW |
Impedance | 35Ω |
Frequency response | 8Hz - 65kHz |
Cable | 2x Jack 3.5mm to 1x Jack 6.35mm Copper conductors Length : 1.5m |
Weight | 404g |
Color | Black |
Color | Black |
Impedance (Ω) | 35 |
Efficiency / Sensitivity (dB) | 90.0 |
Lowest frequency (Hz) | 8 |
Highest frequency (Hz) | 65000 |
Wireless | No |
Cable termination | Jack 6.35mm |
Headphone / Earphone connector | Jack 3.5mm |
