By buying this product you get 91 loyalty points
HiFiMAN's Mini Shangri-La are carefully designed electrostatic headphones. Electrostatic technology coupled with a nanometric membrane means you can count on a level of sound reproduction of rare quality, so you can enjoy your tracks in every detail.
The Mini Shangri-La headphones feature an electrostatic driver design. The basic principle of this technology is to place a static electric charge on a membrane floating between two perforated metal plates. When an electrical voltage is applied to the plates, the adhesion and repulsion of the static electricity causes the membrane to vibrate without direct physical contact. The advantage of this system is that the membrane produces a perfectly uniform sound signal, greatly reducing the diffraction of sound and therefore enabling sound reproduction of staggering fidelity. It should be noted, however, that electrostatic headphones require a specially dedicated amplifier because of the voltage of several hundred volts needed to operate them.
HiFiMAN's Mini Shangri-La headphones have a membrane only a few nanometres thin. This technical feat increases the bandwidth beyond the audible spectrum (7hz to 90,000hz), extending the bandwidth to reveal the last primordial octaves of your favourite recordings, revealing a wealth of previously unknown detail.
HiFiMAN has decided to apply two types of protection to the outside of its earpieces. Firstly, a nanometre-thin layer prevents dust or any other pollutant from infiltrating the inside of the headphones and causing distortion. The second protection takes the form of a honeycomb grid, which protects the driver from airflow vibrations, guaranteeing faithful, accurate sound reproduction.
Technicals caractheristics
Product type | Headphone |
Headphone type | Open back |
Headphone format | Circumaurale |
Headphone technology | Electrostatic |
Headphone connectic | 5-pins electrostatic connector |
Frequency response | 7Hz - 90kHz |
Bias Voltage | 550V-650V |
Weight | 320g |
Color | Silver |
Conditionnement | 1x Headphones Hifiman Mini Shangri-La |
Color | Silver |
Impedance (Ω) | NC |
Efficiency / Sensitivity (dB) | N/A |
Lowest frequency (Hz) | 7 |
Highest frequency (Hz) | 90000 |
Wireless | No |
Cable termination | 5-pin connector |
Headphone / Earphone connector | Non-detachable cable |
