0.9m long pre-cut cable
Refurbished product - Grade S
This product is sold in the form of 0.9m offcut pieces of cable.
The Neotech NEI-1001 II is a balanced modulation cable made of 2 Silver UP-OCC conductors with a cross section of 1.17mm². Each conductor is composed of 4 strands of different sizes. The conductors are kept equidistant thanks to the use of PE tubes. The cable is covered by a PVC-jacket and covered with a nylon braided jacket.
| Specifications | |
| Product type | Interconnect cable |
| Conductors | UP-OCC Silver |
| Conductors section | 2x 1.17mm² |
| Shieldinh | Cu-Mylar foil Braided SPC PTFE tape |
| Sheath | PVC |
| Cover sleeve | Braided nylon |
| External diameter | Ø11.5mm |
| Length | 0.9m |
| Diameter (mm) | 11.5 |
| Length (m) | 0.9 |
| Number of conductors | 2 |
| Insulation material | PE |
| Shielding | Yes |
| Section (mm²) | 1.17 |
| Conductors material (Cable) | Silver |
| Conductors Plating (Cable) | None |
| Refurbished Grade | Grade S |
| Ground / Shielding | Yes |
