MEZE AUDIO 105 AER Headphones
Meze Audio 105 AER headphones are dynamic circumaural open-air headphones featuring a high-performance, long-lasting audiophile design. In fact, the 105 AER's design is based on top-of-the-range components and materials, delivering exceptional sound quality. It features two dynamic dual-diaphragm transducers, each no less than 50mm in diameter, for extended frequency response from 5Hz-30kHz. In addition, its enhanced sensitivity of 112dB and 42-ohm impedance guarantee a high level of compatibility with all types of Hi-Fi equipment.
By buying this product you get 39 loyalty points
Reference : 20412
399,00 €tax incl.
332,50 € tax excl.
Meze Audio 105 AER Open-Back Dynamic Circumaural Headphones 112dB 42 Ohm 5Hz-30kHz
Photo of Meze Audio 105 AER
In terms of sound reproduction, the bass is sustained but controlled, the midrange natural and the treble fine and detailed, for a balanced and versatile overall sound signature. A detachable 3.5mm jack cable and 6.35mm jack adapter are included. The little brother of the Meze Audio 109 PRO, it's an affordable alternative that's no less powerful.
Exploded view of headphones and photo of worn headphones
Meze Audio 105 AER: Audiophile sound reproduction
Thanks to these dynamic Ø50mm transducers, the 105AER is able to reproduce immersive bass and detailed highs for perfect balance. Moreover, their open design offers a wide soundstage for a rich listening experience where each instrument and voice is clearly distinct. Highly versatile, these headphones can be adapted to a wide range of musical genres for a pleasant listening experience in every possible situation.
The Meze Audio 105 AER in action
Meze Audio 105 AER: High-end design
The 105AER headphones feature a “W”-shaped dome made of carbon-fiber-reinforced cellulose. It's thanks to this dome in particular that it's able to reproduce high frequencies with such a high level of detail and finesse. This material also helps to reduce harmful resonances, thus greatly reducing distortion. The membrane surrounding the dome is made of PEEK (Polyether Ether Ketone), a material with excellent mechanical properties. PEEK is very rigid, but also very light and has good tensile strength, enabling every note to be brought to life down to the smallest detail. Finally, a copper-zinc alloy stabilizer absorbs vibrations to remove any remaining distortion.
Photo of the Meze Audio 105 AER transducer
Meze Audio 105 AER: Comfortable ergonomics
A headband distributes the weight of the headphones perfectly over the user's head, for comfort and ease of use during long listening sessions. The ear cushions are made of velvet for optimum passive isolation and a soft, breathable feel.
Zoom in on the Meze Audio 105 AER
Meze Audio 105 AER: Durable materials
The headband of the 105 AER headphones is made of cellulose and carbon fiber composite, for maximum lightness and strength. The shells are made of ABS, offering enhanced shock resistance, while the transducer grilles combine solidity and aesthetics thanks to their special shape.
Photo of the Meze Audio 105 AER shell
Meze Audio 105 AER package photo
Meze Audio 105 AER: A detachable cable
The Meze Audio 105 AER is equipped with a detachable cable, offering the possibility of replacement or upgrade for extended headphone life or simply upgrading. The cable supplied has 3.5mm TS jack connectors on the headphone side and a 3.5mm TRS jack termination. This ensures a high level of compatibility with most audio sources. Meze has also integrated a 6.35mm jack adapter if required.
Product typeHeadphones
Headphones typeOpen-back
FormatCircumaural
Transducer typeDynamic
Transducers diameterØ50mm
Frequency response5Hz-30kHz
Sensibility112dB SPL (1kHz, 1mW)
Impedance42 ohm
MaterialABS shells
Zinc and steel structure
Leather headband
Velvet ear pads
Detachable cable
Headphone connectorsJack 3.5mm TS
TerminaisonJack 3.5mm TRS
Cable length1.8m
Cable with built-in microphone
Gross weight1.2kg
Package1x Meze Audio 105 AER headphones
1x Detachable 3.5mm jack cable
1x 6.35mm jack adapter
1x Storage pouch
Impedance (Ω)42
Efficiency / Sensitivity (dB)112.0
Lowest frequency (Hz)5
Highest frequency (Hz)30000
WirelessNo
Cable terminationJack 3.5mm
Cable terminationJack 6.35mm
Headphone / Earphone connectorJack 3.5mm
MEZE AUDIO 105 AER Open-Back Dynamic Circumaural Headphones 112dB 42 Ohm 5Hz-30kHz
Meze Audio 105 AER headphones are dynamic circumaural open-air headphones featuring a high-performance, long-lasting audiophile design. In fact,...
