By buying this product you get 39 loyalty points
The Meze Audio 105 AER are dynamic circumaural open-back headphones designed to deliver outstanding audiophile performance in a durable structure. In fact, the 105 AER's design is based on top-of-the-range components and materials, delivering exceptional sound quality. It incorporates two dynamic double-diaphragm transducers, each no less than 50mm in diameter, for an extended frequency response of 5Hz-30kHz. In addition, its 112dB sensitivity and 42-ohm impedance guarantee a high level of compatibility with all types of Hi-Fi equipment.
In terms of sound, the 105 AER stands out for its deep but controlled bass, natural midrange and precise, detailed highs, offering a balanced, versatile sound signature. A detachable 3.5mm jack cable and 6.35mm jack adapter are included. A little brother to the Meze Audio 109 PRO, it represents a more affordable but no less high-performance alternative.
Thanks to its dynamic Ø50mm transducers, the 105 AER is capable of reproducing immersive bass and detailed highs for a perfectly balanced sound experience. he open design of the headphones broadens the soundstage, offering rich reproduction where every instrument and every voice finds its place. Highly versatile, these headphones can be adapted to a wide range of musical genres, for a pleasant listening experience in any situation.
The Meze Audio 105 AER headphones feature a “W”-shaped dome made of carbon-fiber-reinforced cellulose. It's thanks to this dome in particular that it's able to reproduce high frequencies with such a high level of detail and finesse. What's more, this material greatly helps to reduce unwanted resonances, thus contributing to a significant reduction in distortion.
The membrane surrounding the dome is made of PEEK (Polyether Ether Ketone), a material with excellent mechanical properties. PEEK is very rigid, but also very light and has good tensile strength, enabling every note to be brought to life in the finest detail. A copper-zinc alloy stabilizer completes the design, absorbing vibrations and eliminating the last traces of distortion.
The ergonomic headband perfectly distributes the weight of the headphones on the user's head for optimum comfort, enabling long listening sessions to be enjoyed without discomfort. The velvet earpads provide optimum passive isolation and a soft, breathable feel.
The headband of the 105 AER headphones is made of cellulose composite and carbon fiber, for maximum lightness and strength. The shells are made of ABS, offering enhanced shock resistance, while the transducer grilles combine solidity and aesthetics thanks to their special shape.
The Meze Audio 105 AER features a detachable cable for replacement or upgrading, for extended headphone life or simply for upgrading. The cable supplied has 3.5mm TS connectors on the headphones side and a 3.5mm TRS termination. This ensures a high level of compatibility with most audio sources. Meze also supplies a 6.35mm jack adapter if required.
Product type | Headphone |
Headphone type | Open-Back |
Format | Circumaural |
Transducer type | Dynamic |
Transducer diameter | Ø50mm |
Frequency response | 5Hz-30kHz |
Sensitivity | 112dB SPL (1kHz, 1mW) |
Impedance | 42 ohm |
Material | ABS shells Zinc and steel structure Leather headband Velvet pads |
Detachable cable | |
Headphone connectors | Jack 3.5mm TS |
Terminaison | Jack 3.5mm TRS |
Cable length | 1.8m |
Cable with built-in microphone |
Gross weight | 1.2kg |
Package | 1x Meze Audio 105 AER headphones 1x Detachable Jack 3.5mm cable 1x Jack 6.35mm adapter 1x Storage pouch |
Color | Black |
Impedance (Ω) | 42 |
Efficiency / Sensitivity (dB) | 112.0 |
Lowest frequency (Hz) | 5 |
Highest frequency (Hz) | 30000 |
Wireless | No |
Cable termination | Jack 3.5mm |
Cable termination | Jack 6.35mm |
Headphone / Earphone connector | Jack 3.5mm |
