MONOLITH M1060C Planar Magnetic Closed Back headphones 90dB 18 Ohm 10Hz - 50kHz
The Monolith M1060C headphones feature redesigned planar magnetic drivers capable of reproducing a detailed and accurate soundstage in a closed-back design. Low distortion and perfectly balanced sound make the M1060C a true ally for audiophiles and music lovers who want to enjoy a high level of sound reproduction.
By buying this product you get 44 loyalty points
Reference : 16309
449,00 €tax incl.
374,17 € tax excl.
Shipping date: 07-04-2026.
Monolith M1060C Casque Fermé Planar Magnetic 90dB 18Ω 10Hz - 50kHz
Planar Magnetic Technology
Planar Magnetic drivers
The M1060C's magnetic planar drivers have been completely redesigned from those adopted by its predecessor, the M1060. Several improvements have been made, including a new balanced magnetic structure that allows the driver to be much more efficient in a closed cabinet. The result is a very low distortion, a greater linearity and a spectacular sound image.
Closed back design
With the M1060C, outside noise stays outside! Offering excellent audio isolation, the M1060C allows for undisturbed listening, just as those around you will not be disturbed by the sound of your headphones. An ideal headphone for listening sessions in noisy environments.
Comfort
The M1060C is designed to be comfortable even during long listening sessions. Its large, comfortable leatherette-covered earpads and padded headband prevent pain and fatigue.
Product typeAudio heaphones
StyleClosed back
Transducer typePlanar magnetic
Magnetic structure asymmetryNéodyme push-pull
Magnet typeHigh grade N50 neodymium
Drive sizeØ106mm
Maximum power handling5W Max.
Maximum SPL> 120dB
Frequency response10Hz - 50kHz
THD< 1% @ 1mW, 1kHz
Impedance18Ω
Efficiency90dB /1mW
Optimal power requirement1W
Weight483g
ColorWalnut
Impedance (Ω)18
Efficiency / Sensitivity (dB)90.0
Lowest frequency (Hz)10
Highest frequency (Hz)50000
WirelessNo
Cable terminationJack 3.5mm
Cable terminationJack 6.35mm
Headphone / Earphone connectorJack 2.5mm
3 reviews
agréable
Le casque est volumineux mais son port est confortable ; on à tendance à l'oublier . Le son est détaillé et le rendu spatial séduisant et pas caricatural . Un bon compromis pour moins de 300 euros . Fait aussi bien que certains casques plus chers .
This review has been posted for MONOLITH M1060C Planar Magnetic Closed Back headphones 90dB 18 Ohm 10Hz - 50kHz
Un son de grande qualité.
Un rapport prix qualité du son imbattable. Que ce soit sur l'AudioGD NFB 29-38 ou sur le Musical Fidelity X-Can 3 la musique prend une dimension tridimensionnelle que peu de casque même plus chers sont capables de faire naitre .
La première demi heure d'écoute permet de redécouvrir les enregistrement même amateurs sur ce casque extraordinaire d'ouverture et de "spacialisation ". Contrairement au Elegia de chez Focal le son n'est pas en fermé dans la boite, et la vraie dimension des lieux de prise de son apparaît... JMD
The Monolith M1060C headphones feature redesigned planar magnetic drivers capable of reproducing a detailed and accurate soundstage in a...
