SIVGA SV023 Over Ear Open-Back Dynamic Headphone 300 Ohm 105dB 20Hz-40kHz
The Sivga SV023 open-back headphones offer an elegant and sober design, combined with excellent sound performance. It integrates dynamic 50mm drivers with LCP (Liquid Crystal Polymer) composite membrane and Beryllium plating for an expressive reproduction with a beautiful extension on all the sound levels.
Reference : 16512
490,00 €tax incl.
408,33 € tax excl.
Sivga SV023
Casque dynamique ouvert circumaural 300Ω 105dB 20Hz-40kHz
Sivga SV023 Casque Dynamique Ouvert Circumaural 300Ω 105dB 20Hz-40kHz
Each headset features a precision CNC-machined solid walnut shell finished by hand by craftsmen. The generously padded and micro-perforated ear cushions provide a comfortable fit, as does the padded headband.
A wide, dynamic and perfectly ventilated sound stage
The Sivga SV023's driver has a chassis made of aircraft-grade aluminum alloy. Its cone is made of a composite LCP film and a beryllium-plated dome. The whole is driven by a high performance neodymium NdFeb magnet. The thin composite LCP film has elastic properties and a very low dielectric strength. The high-frequency vibrations are thus perfectly controlled and their rapidity makes it possible to offer superb transients. The bass is precise and deep, the midrange soft and round, and the highs natural and chiseled.
Light and comfortable
The SV023 headband is made of memory foam and covered with goat leather, selected for its comfort, softness and durability. The stainless steel frame is lightweight and provides optimal clamping force, applying no uncomfortable pressure to the head.
Solid wood earpieces
The headset's earpieces are precision-machined with a CNC (computer numerical control) directly from a specially selected piece of high quality walnut wood. Sanding and varnishing are meticulously done by hand by Sivga Audio craftsmen. The central part of the earpiece allows the opening of this one, displaying a stainless steel grill surrounded by an aluminum ring.
A design of ear cushions offering comfort and ventilation
The SV023's ear cushions are also made of memory foam and are covered with leatherette and velvet, ensuring excellent comfort. The ergonomic design of the ear cushions allows them to perfectly fit the shape of the listener's skull and the micro-perforated leatherette allows the ear to breathe, thus avoiding perspiration.
Detachable high purity copper cable
The detachable cable supplied with the SV023 integrates pure 6N OCC copper conductors and ensures an optimal transmission of the audio signal. Its balanced Pentaconn 4.4mm jack connector allows a direct connection to the vast majority of audiophile portable audio players (DAP) on the market or to an amplifier with a corresponding balanced output.
Product typeHeadphone
Headphone typeOver-ear
Headphone structureOpen back
Driver typeDynamic
Driver sizeØ50mm
Frequency response20Hz - 40kHz
Sensitivity105dB ±3dB
Impedance300Ω ±15%
Cable length2m
ConnectorBalanced Jack 4.4mm Pentaconn
Weight318g
Package1x Sivga SV023
1x Hard leather carrying case
1x Flexible carrying pouch for cables
1x Balanced Jack 2.5mm to Jack 4.4mm cable
1x Jack 4.4mm to Jack 3.5mm adapter
1x Jack 3.5mm to Jack 6.35mm adapter
ColorWalnut
Impedance (Ω)300
Efficiency / Sensitivity (dB)105.0
Lowest frequency (Hz)20
Highest frequency (Hz)40000
WirelessNo
Cable terminationUSB-C
Cable terminationJack 4.4mm
Cable terminationJack 6.35mm
Cable terminationJack 3.5mm
Headphone / Earphone connectorJack 2.5mm
The Sivga SV023 open-back headphones offer an elegant and sober design, combined with excellent sound performance. It integrates dynamic 50mm...
