FURUTECH FA-αS22 Balanced Interconnect Cable PC-OCC Ø9mm
4.9 / 5
Reference : 11383
72,00 €tax incl.
60,00 € tax excl.
Shipping date: 03-06-2025.
Câble vendu au mètre
The treatment of α Alpha copper from Furutech OCC drivers is favored by Furutech engineers to excel in sound reproduction.
The α (Alpha) OCC treatment is done with high purity oxygen-free copper using a particular technological cooling process at very low temperature.
Unlike OFC cables, virtually all impurities are removed at the micron using a special Furutech single casting process.
Electrical characteristics:
  • Maximum conductor resistance: Ω / km 13 (JISC3005 6 20 ℃)
  • Minimum insulation resistance: MΩ‧m> 100 to 1000V 20 ℃
  • Capacitance: PF / M 84.1 at 1KHz
  • Impedance: Ω 37.7 to 10 MHz
  • Inductance: uH / M 1.55 at 1KHz
  • Dielectric strength: V / 1 min. AC 1000 (JISC3005 8)
Mechanical characteristics:
  • Conductor Type: Copper α (Alpha) OCC
  • Internal construction 60 strands of 0.18mm each
  • Insulation Type: Audio Type Resin (Red and White)
  • Diameter: 2.6mm
  • Internal structure: 2 twisted strands together
  • Mechanical damping: Quality cotton Audio and wrapped paper
  • Shielding: (Alpha) Braided conductor
  • Jacket Material: Flexible PVC soft PVC (dark green)
  • Sheath Thickness: 1.0mm
  • External Diameter: 9mm
Diameter (mm)9.0
Length (m)Sold by length
Number of conductors3
Insulation materialPVC
ShieldingYes
Section (mm²)N/A
Ground / ShieldingYes
17 reviews
Vraiment très bien tout en pouvant être un peu exigeant...
Plantons le décors...
Le guitariste que je suis (doté de son propre studio avec batterie, clavier, ...), écoute la musique avec ce qui suit :
- Node 2i alimenté via Shanti + carte PD Creativ
- Nuprime DAC 9SE (connexion Toslink QED Quartz Reference)
- Nuprime STA 9X
- Epos EPic 5 subtilement mais sensiblement remaniées (bcp + d'ampleur et de nuance)
- Liaison enceintes Ludic Silenos (exemplaire de nuance et de vérité)
- filtrage EDF via BADA 6610
...le tout dans 38m2 sous 2,80m sous plafond.
Séduit par le concert de louanges concernant ce Furutech, je l'ai inséré en symétrique entre les deux Nuprime (XLR Switchcraft + soudure Mundorf Supreme).
Ces FA-aS22 distribuent les timbres de façon très fine et aérienne avec une grande liberté, le tout avec une grande justesse tout en étant très rigoureux.
Ils ne tordent ni ne surjouent jamais, ne sont jamais durs, et restent très subtils et délicats, la scène proposée entre les enceintes est très "cinémascope".
C'est très beau, l'air circule indubitablement partout, le sentiment de lumière prédomine.
Je me suis néanmoins retrouvé confronté "à la longue" à un résultat un peu "court sur pattes" sur les jeux de batterie (j'en ai une dans mon studio), traduisant un léger manque de soutien et de matière sur les coups de pédales de grosse caisse et les jeux de basses (guitares, contrebasses, violes de gambe, ...).
Le plaisir procuré par ces FA-aS22 était au fond mâtiné d'une pointe de frustration.
Sans remettre en cause ces excellents câbles, j'ai finalement migré vers du Neotech Nemoi 3220 (mêmes XLR, même soudure) sans retour arrière possible.
En résumé, si ces Furutech sont vraiment de haute voltige, ils peuvent ne pas convenir dans toutes les situations.
This review has been posted for FURUTECH FA-αS22 Balanced Interconnect Cable PC-OCC Ø9mm
Sehr empfehlenswert!
Bei mir ist dieses Kabelmodell schon seit mehreren JAhren in Gebrauch. Sie wollen es höherwertiger ? Das dürfte schwierig werden. I
Konfektionieren Sie es (unbedingt mit hochwertigeren) Furutech Cinch Steckern und sie werden zufrieden sein.
In dieser Preisklasse bekommen Sie nur noch ein gebrauchtes Tellurium Black Cinch Kabel, das klanglich ebenfalls in dieser Liga spielt, aber in Bezug auf Klarheit und Auflösung nicht ganz das Niveau dieses Furutech Kabels erreicht.
Le Graal ?
Après plusieurs essais décevants avec différents câbles au mètre de tarifs plus abordables, j’ai décidé de casser ma tirelire pour voir si la qualité avait un prix. La réponse (malheureusement pour ma tirelire) est oui.
J’ai fini par trouver le son qui convenait à mes vieilles oreilles et à mon installation car comme vous ne l’ignorez pas, tout est très subjectif.(Enceintes Cantilène, Pré ampli tube, ampli classe A)
Ce Furutech FA-aS22 est un enchantement pour moi sur beaucoup de registre, (pas tout à fait neutre mais est-ce que cela existe ?) La musique coule tel un ruisseau sous les feuillages au printemps avec ce petit clapotis...Pardon, je m’égare. Je n’ai plus cette sensation désagréable que le grave n’est pas tenu, que le médium est en avant, que l’aigu est tronqué ou trop agressif. Tout est là, devant vous, en live. Les voix sont charnelles et l’intonation me semble juste. Bref, vous l’aurez compris, ce Furutech qui m’accompagne depuis maintenant plusieurs mois me ravit. Je ne regrette absolument pas mon investissement.
Je l’ai associé à des connecteurs RCA Ramm Audio et câblé le fil rouge au point chaud et le fil blanc à la masse avec la tresse à la masse côté source uniquement.
Connecteurs RCA Ramm Audio à visser 30891-GT vendu sur ce site. (voir avis)
Qu’est-ce qu’on dit ? Merci Audiophonics.
RQP excellent
Câble acheté chez Audiophonics, j'ai fait monter avec contacteurs Furutech FT 111 pour permettre d'avoir un prix contenu, ce câble est hyper agréable à écouter, très immersif et fluide, nous place à l'intérieur de la musique, très bonne dynamique. J'utilise avec un lecteur CD à tubes. Dans ce segment de prix, il y a peu d'offres, je ne connaissais Furutech, très bon. A recommander, je ne peux que confirmer avis précédents.
Excellent!
C'est le meilleur câble au mètre que j'ai pu tester! Bande passante,
dynamique,définition,timbres et musicalité sont au sommet de ce
que je connais! Je n'ai pas tout testé et il y a sans doute encore
mieux,mais à quel prix???!!!
