NEOTECH NEI-1002 Interconnect Cable UP-OCC Silver Triple Shielding Ø11.5mm
The Neotech NEI-1002 is a modulation cable consisting of two single crystal UP-OCC silver conductors. These conductors are maintained at equidistance thanks to the use of PE tubes and insulated with PE jackets. A triple shielding drastically limits the impact of interference, with a PTFE layer, an Al-Mylar foil and a silver-plated copper braid.
Reference : 15836
125,00 €tax incl.
104,17 € tax excl.
Last items in stock !
Shipping date: 07-04-2026.
Câble au mètre
Neotech NEI-1002
Interconnect cable UP-OCC silver triple shielding
Neotech NEI-1002 Câble de modulation Argent UP-OCC Triple Blindage
The Neotech NEI-1002 is a modulation cable consisting of two single crystal UP-OCC silver conductors. These conductors are maintained at equidistance thanks to the use of PE tubes and insulated with PE jackets. A triple shielding drastically limits the impact of interference, with a PTFE layer, an Al-Mylar foil and a silver-plated copper braid. The cable is finally covered by a PVC sheath and dressed with a Nylon braided sheath.
specifications
Product typeInterconnect cable
Conductors materialUP-OCC silver
Conductors section2x AWG22 (0,33mm²)
ShieldingFeuille Al-Mylar
Braided silver plated copper
PTFE foil
SleevePVC
Covering sleeveBraided nylon
external diameterØ11.5mm
QuantitySold by the meter
Diameter (mm)11.5
Length (m)Sold by length
Number of conductors3
Insulation materialPE
Insulation materialPTFE
ShieldingYes
Section (mm²)1.17
Conductors material (Cable)Silver
Ground / ShieldingYes
4 reviews
Neotech nei1002
EXCELLENT.....Thank you.!!!!!!!
This review has been posted for NEOTECH NEI-1002 Interconnect Cable UP-OCC Silver Triple Shielding Ø11.5mm
Wow!
Upgraded from this from
A cheaper neotech and feels like i have got new life in my speakers. Very transparent and open. Never hard sounding. Used Wbt 0158 cu. Not easy to build but worth it.
Impressive
This wire, using ETI Kryo XLRs, replaced a set of NEI-3001 mkIII going from dac to preamp. I was worried that the shift from copper to silver, and from 17awg to a 22awg wire would have a negative effect on tonal balance. After about 200 hours, those worries were unfounded. Beautiful tone, detail, and staging. The only negative is that I'm still curious about NEI-1001.
Great cable
Although i am a fun from the copper cables ,i did try the Neotech nei-1002 occ silver.
Absolutely top quality from Neotech, it sounds Crystal clear,with a large soundstage.
Audiophonics fast shipping as usual ,good package .
My only complaint is that Audiophonics sale cables only 1 meter size.
They should begin to sale cable's in 0,50 cm ,it wil be better for the customers and for the business.
 (10)
The Neotech NEI-1002 is a modulation cable consisting of two single crystal UP-OCC silver conductors. These conductors are maintained at...
