NEOTECH NEI-3004G Balanced Interconnect Cable
Neotech's NEI-3004G modulation cable is a symmetrical modulation cable incorporating 2 G-UPOCC composite conductors, a combination of OCC copper and graphene. This new conductor marks a significant advance, both in terms of research and industrial applications. The addition of graphene improves the stability of electrical signal transmission at high temperatures, while preserving the exceptional conductivity of OCC copper, so that performance remains intact, even at high voltages.
Reference : 19315
21,90 €tax incl.
18,25 € tax excl.
Câble vendu au mètre
NEOTECH NEI-3004G Balanced Interconnect Cable G-UPOCC Graphene Ø8.5mm
NEOTECH NEI-3004G : macro view
NEOTECH NEI-3004G : Details of cable composition
The conductors have polyethylene insulation, preventing any transmission of electrical discharge created by the double mylar/aluminium shielding and OCC copper foil. The whole assembly is encased in a sheet of paper with cotton fibres for mechanical strength, then covered with a robust, flexible PVC sheath.
Product typeBalanced interconnect cable
Conductor materialUP-OCC copper with graphene (G-UPOCC)
Conductors2x multi-strand conductors
InsulationPolyethylene
PVC outer sheath
ShieldingAL MYLAR aluminum foil
OCC braided copper foil
Textile paper
External diameterØ8.5mm
ColorRed
PackageSold by the meter
Diameter (mm)8.5
Number of conductors2
Insulation materialPE
ShieldingYes
Section (mm²)N/A
Conductors material (Cable)Graphene
Ground / ShieldingYes
5 reviews
Excellent câble
Très bon câble sur tout le spectre
Amène de la clarté et pleins de détails deviennent plus apparents.
Je recommande son achat
This review has been posted for NEOTECH NEI-3004G Balanced Interconnect Cable G-UPOCC Graphene Ø8.5mm
Excellent
câble équilibré, naturel, sans acidité, juste parfait. Entre mon DAC et mon intégré Il est équipé des xlr eizz ez-206, j'ai rien entendu d'aussi naturel. En fait, je crois que c'est la 1ere fois que j'ai l'impression d'écouter la musique sans "entendre" le câble.
Excellente découverte, tout comme le cable secteur de la même marque NEP-3003G. J'ai équipé le dac avec ce dernier et rien a redire, ça le fait.
Enfin !
Je n' ai jamais trop apprécié les câbles Neotech ( y compris le nemoi 1220), mais celui ci fait exception a la regle. Équilibré, construction cogérante et section de bonne dimension.
Très bon câble.
Ecxellent
Sonne très bien dès le branchement.
C'est clair, spatialisé, détaillé, des basses quand il y en a, respecte très bien les enregistrements.
monté avec RAMM AUDIO 30891-RT
Utilisé entre Atoll MS120 et Naim Supernait3 avec JMR Cantabilé jubilé.
J'ai hâte de l'entendre vieillir un peu
Phenomenal
Phénoménal Câble fabuleux à tous les niveaux, gamme de fréquences étendue, séparation instrumentale, image 3D immense. Une grande transparence conserve cependant un raffinement et une émotion appropriés sans jamais paraître analytique ou froid. Câble très bien construit avec maille de cuivre occ, une bénédiction, les deux conducteurs étaient reliés au point positif et la maille au négatif. Une partie de la magie de ce câble peut être due à la nouvelle technologie consistant à ajouter du graphène aux conducteurs. Pour moi, c'est le meilleur que j'ai jamais entendu et j'ai entendu de nombreux artistes de haut niveau comme Kimber kS et Nordost Heindall par exemple. Bien entendu, les meilleurs câbles du futur devront utiliser du graphène. Neotech a pris la tête de la révolution technologique en matière d'excellence en matière de conduite électrique. Les nouveaux câbles d'enceintes devraient avoir les mêmes vertus sonores. Cela vaut le prix élevé, mais cela vaut chaque centime. envoyé un SMS du CD au pré aux vannes et du pré à un moteur Rotel RB 1552.
Neotech's NEI-3004G modulation cable is a symmetrical modulation cable incorporating 2 G-UPOCC composite conductors, a combination of OCC...
