These HP cable reducers allow you to insert a bare conductor to benefit from a 2mm banana plug. This particular format is especially useful for quick connection with clamp terminals, used on some speaker models and HiFi devices. The reducers are gold plated to ensure good conductivity and resistance to oxidation.
These banana plugs are affordable, but no less high quality. Their gold-plated copper contact resists corrosion and oxidation. Their body is made of carbon fiber, a strong and durable material. They accept a maximum cable diameter of Ø6mm, and are easily mounted using two screws to hold the cable and contacts in place.
Following a long period of research and development by KLEI, the brand offers banana plugs with exceptional performance, thanks to pure copper contacts> 101 IACS and a silver plating.
Mundorf banana plugs are made from a special alloy of copper and beryllium which is then gilded. Beryllium gives Copper the necessary flexibility to adapt to banana connectors and thus maintain better contact.
These Neotech NC-01675RH banana plugs feature excellent design quality and are ideal for creating high-performance HiFi speaker cables. The contacts are made of Rhodium-plated OFC Copper, ensuring both very good conductivity and resistance to oxidation.
Neotech's NCB-80 banana plugs are made from high-purity OFC copper and are gold-plated for optimum resistance to corrosion and oxidation. A cryogenic treatment has also been applied to the contacts to improve their conductivity and durability. NCB-80 banana plugs accept cables up to Ø5mm in diameter.
The Oyaide SGBN are high quality banana plugs for high performance speaker cables. They are double plated with silver and 24k gold to ensure perfect signal transmission. In addition, their finned design ensures maximum contact with the terminal block. They accept cables up to 4mm in diameter. Mounting the cable in the banana plug is very simple with two...
This PANGEA Xtreme connector, made entirely from Tellurium copper, is ideal for making high-quality loudspeaker cables. It will be the ideal companion for custom-made Do IT Yourself OCC copper cables.Key points:100% Tellurium copper connector body Screw or solder
These BFA RAMM AUDIO 20100GT banana plugs have phosphor copper contacts with direct 24k gold plating for oxidation and corrosion resistance and optimum conductivity.
RAMM AUDIO's 20800-RT banana plugs are made of tellurium copper contacts, offering far superior conductivity than conventional copper alloys such as brass. Furthermore, these plugs are Rhodium plated for outstanding protection against oxidation, while offering excellent conductivity. What's more, a cryogenic treatment is applied to achieve optimum...
These speaker cable adapters transform a 4mm banana plug into a speaker terminal spade. This will enable you to easily adapt your banana cables to the spade connectors used on certain speaker models and Hi-fi equipment. These adapters feature 24k gold plating to ensure maximum protection against oxidation, while maintaining excellent conductivity.
These interconnecting banana plugs are ideal for quick connection/disconnection of a pair of speakers or to extend a cable easily and quickly. They also provide good conductivity with gold-plated copper contacts.
These Speaker Snap banana plugs are gold-plated for optimum resistance to corrosion and erosion. They also feature an extremely practical mounting system that requires no tools.
The BP400 Triangle banana plugs ensure both an optimal contact between the cable and the terminal block due to their shape, while ensuring an optimal electrical conductivity. The contacts are silver plated for a perfect signal transmission.
Viablue T6s banana plugs offer excellent design quality for high-performance cable design. Their contact is 24k gold plated offering very good conductivity and resistance to oxidation, and their "sawtooth" shape ensures optimal contact between the connector and the terminal block.
Viablue T8 banana plugs offer excellent design quality for high-performance cables. Their contact is plated with 24k gold for excellent conductivity and resistance to oxidation. The connector body is made of aluminum. Assembly is extremely simple, thanks to an M4 hexagon socket screw.
Viablue's 24k gold-plated T8 banana plug contacts allow you to make your own cables by soldering the contact directly to the conductor. You can also screw these plugs to the body of Viablue T8 banana plugs, allowing you to replace faulty connectors, for example.
Viablue TS2 banana plugs use a tube connection system to ensure maximum contact with the speaker terminals. When connecting the banana plug to the terminal block, the cylinder, divided into two parts along a sinusoidal line, ensures a constant and regular pressure over its entire surface. This ensures an optimal contact surface and a firm hold of the...
