Banana Plugs Gold Plated Lockable Ø9mm (The pair)
These affordable banana plugs allow a quick and easy connection to the terminals of your speakers and amplifiers, while ensuring an optimized contact. The contacts are gold-plated to ensure excellent signal conductivity. The connectors are also lockable, with a spring-loaded system that allows the plug's fins to be spread apart for a perfect fit in the terminal blocks.
Reference : 15636
7,90 €tax incl.
6,58 € tax excl.
Shipping date: 07-04-2026.
Banana Plugs
Fiches Bananes Plaquées Or Ø9mm Verrouillable (La paire)
These affordable banana plugs allow a quick and easy connection to the terminals of your speakers and amplifiers, while ensuring an optimized contact. The contacts are gold-plated to ensure excellent signal conductivity. The connectors are also lockable, with a spring-loaded system that allows the plug's fins to be spread apart for a perfect fit in the terminal blocks. The cables are held firmly in place by two screws. These plugs accept cables up to 9mm in diameter.
Product typeBanana plugs
Contacts materialCopper alloy
PlatingGold
Max cable diameterØ9mm
Max. conductor diameterLoose screws : Ø8mm
Tightened screws : Ø5.5mm
Mounting typeTo screw
Total dimensionsØ14.5 x 57.5mm
Max cable diameter (mm)9.0
ConnecticMale
ConnectorBanana
3 reviews
Big banana
On peut en mettre du câble !!! J'ai relié 2 *4mm y'a encore de la place. Système de blocage efficace. Belle qualité de fabrication.
This review has been posted for Banana Plugs Gold Plated Lockable Ø9mm (The pair)
Magnifiques pour câble HP de forte section.
Achetées pour y brancher dedans mon câble HP Sommercable Elephant en 2x4mm2 soit 8mm2 de section.
C'est parfait, ça rentre facilement et il y a même de la marge jusqu'à 10mm2 de section de câble.
Le serrage par écartement de la fiche banane est simple et efficace, on ne risque pas de voir la prise se débrancher par accident.
Un tout petit reproche pour la route... j'aurais préféré des vis à clé Allen plutôt que des vis fendues pour un meilleur serrage.
Mais compte tenu du petit prix, c'est top.
Merci à Audiophonics pour la qualité des emballages et pour la rapidité de livraison !
Fiches banane à verouillage
Excellente fabrication , acceptent de forts diamètres de câble, verrouillage impeccable grâce au diamètre de bague extérieure important.
These affordable banana plugs allow a quick and easy connection to the terminals of your speakers and amplifiers, while ensuring an optimized...
