Banana Plugs Rhodium-Plated Lockable Ø9mm (The pair)
These affordable banana plugs allow quick and easy connection to the terminals of your loudspeakers and amplifiers, while ensuring optimized contact. Rhodium-plated contacts ensure excellent signal conductivity. The connectors are also lockable.
Reference : 18139
7,90 €tax incl.
6,58 € tax excl.
Shipping date: 07-04-2026.
Banana Plugs
These affordable banana plugs allow quick and easy connection to the terminals of your loudspeakers and amplifiers, while ensuring optimized contact. Rhodium-plated contacts ensure excellent signal conductivity. The connectors are also lockable, with a spring-loaded system allowing the plug's fins to be spread apart for perfect retention in the terminal blocks. The cables are held firmly in place by two screws. These plugs accept cable diameters up to Ø9mm.
Product typeBanana plugs
Contacts materialCopper
Contact platingRhodium
Max cable diameterØ9mm
Mounting typeTo screw
Total body length57mm
Connector length15mm
Max.body diameterØ14.5mm
Max. conductor diameterLoose screws : Ø8mm
Tightened screws : Ø5.5mm
Identification rings
ColorSilver
Weight26g/Banana plugs
PackageLockable rhodium-plated banana plugs (Pair)
Max cable diameter (mm)9.0
ConnecticMale
ConnectorBanana
Václav Z.
Again, very good value for money. Used on Neotech 3004 MK II cable. Review on the said cable...
This review has been posted for Banana Plugs Rhodium-Plated Lockable Ø9mm (The pair)
These affordable banana plugs allow quick and easy connection to the terminals of your loudspeakers and amplifiers, while ensuring optimized...
