EIZZ EZ-505 Banana Plugs 24K Gold Plated Copper Ø7mm (Pair)
These high quality Eizz EZ-505 banana plugs are made of 24k gold plated copper contacts. They provide excellent conductivity and durability. The assembly is done simply by means of a screwing system.
4.5 / 5
Reference : 15092
12,50 €tax incl.
10,42 € tax excl.
Shipping date: 07-04-2026.
EIZZ EZ-505
EIZZ EZ-505 Fiches Banae Cuivre Plaqué Or 24k Ø7mm (La paire)
Product typeBanana plugs
Max cable diameterØ7mm
Diameter of clamping screwM4 (Ø4mm)
Contacts materialCopper
Contacts platingGold 24k
Connection typeTo screw
ColorGray
Max cable diameter (mm)7.0
Mounting typeTo screw
ConnecticMale
ConnectorBanana
2 reviews
Excellente
Ces bananes sont ce que l’ on attend de bon connecteurs, solide, bien pensé, mécaniquement irréprochable, transparentes et jolies.
Top !
This review has been posted for EIZZ EZ-505 Banana Plugs 24K Gold Plated Copper Ø7mm (Pair)
Impeccable quality, very conductive
With these plugs the production quality is very good. The surface finish looks even better in reality than in the pictures. While the connector shells are all metal including the surface finish, so it is worth noticing that the only non-conducting part of the connector is the colour band. The connector shell is fully connected to the signal, so maybe not recommended to use these in applications with high voltages present while handling.
The spring structure of the golden part is rotating, which means the connector migh be less prone to breaking when twisted inside the mating connector. Robust double screws allow rather thick wires to be used and secure connections to be made. Overall rather decent quality/price ratio and very good build quality.
These high quality Eizz EZ-505 banana plugs are made of 24k gold plated copper contacts. They provide excellent conductivity and durability. The...
