XANGSANE XS-6002AU Banana plugs Gold-plated Ø7.5mm (Set x4)
These Xangsane XS-6002AU banana plugs feature copper alloy contacts with gold plating for enhanced conductivity and resistance to corrosion and oxidation. Their solid body gives them good durability. These banana plugs accept cables with a maximum diameter of Ø7.5mm.
Reference : 18465
16,90 €tax incl.
14,08 € tax excl.
XANGSANE XS-6002AU
These Xangsane XS-6002AU banana plugs feature copper alloy contacts with gold plating for enhanced conductivity and resistance to corrosion and oxidation. Their solid body gives them good durability. These banana plugs accept cables with a maximum diameter of Ø7.5mm. They are mounted using two hexagon socket screws, so no soldering is required. They provide clear signal transmission and stable performance.
Product typeBanana plugs
Contact materialCopper alloy
Contact platingGold
Max. cable diameterØ7.5mm
Identification rings
Total dimensions57x Ø14mm
Weight32g / banana plugs
ColorBlue
PackageSet x4
Max cable diameter (mm)7.5
Mounting typeTo screw
ConnecticMale
ConnectorBanana
2 reviews
Surprisingly quality bananas. I already have some very well-known audiophile brands, but these are not far behind them... or rather, they seem to me to be of the same quality, double screwing of the wire... in short, there is no point in paying for a well-known brand.
This review has been posted for XANGSANE XS-6002AU Banana plugs Gold-plated Ø7.5mm (Set x4)
What a pleasant surprise!
The plugs came packed in a luxury metal box. They have a very well crafted heavy brass body. The gilding looks smooth and thick. The overall appearance is like an expensive product. A real bargain!
These Xangsane XS-6002AU banana plugs feature copper alloy contacts with gold plating for enhanced conductivity and...
