This Neotech Nemos-1160 high-end speaker cable benefits from an all-inclusive design, incorporating the best possible components for maximum conductivity and optimal signal transmission, resulting in high quality sound reproduction.
By buying this product you get 139 loyalty points
The Neotech Nemos-1160 is an uncompromisingly designed cable for high-end loudspeakers, incorporating the best possible components for maximum conductivity and optimal signal transmission, resulting in a high quality sound reproduction. The cable features high purity rectangular OCC silver conductors with a cross-section of 4.2mm² (11AWG), individually insulated with PTFE jackets. Each pair of conductors has an additional PE insulation. The whole is then covered with a PVC inner jacket, a transparent PVC outer jacket and a nylon outer jacket. The particular architecture of the cable also allows a strong reduction of the effect of inductance and capacitance.
Product type | Speaker cable |
Conductors material | Pure OCC Silver |
Conductors section | 4.2mm² (11AWG) |
Insulation | PTFE PE |
External / internal sheath | PVC |
External diameter | Ø12.5mm (x2) |
Color | Blue / Black |
Quantity | Sold by the meter |
Diameter (mm) | 12.5 |
Number of conductors | 16 |
Number of conductors | 8 |
Number of conductors | 2 |
Insulation material | PE |
Insulation material | PTFE |
Shielding | No |
Section (mm²) | 4.2 |
Conductors material (Cable) | Silver |
Conductors Plating (Cable) | None |
Ground / Shielding | No |
