Connector
Connectic
Contacts Material (Connector)
Contacts Plating (Connector)
Mounting type
Accepts Banana Plugs
Max panel thickness
mm
mm
Patrick K.
Sonic Master
This cable is sooooo good that i was shocked. I did not expect this level of warm neutral detailed rich, open and airy sound...
Pierre-Marin L.
Je confirme tous les commentaires élogieux sur ce câble...
Patricio C.
Dale una oportunidad de escucha en tu sistema... y juzgalo tu mismo.
Más vale tener potencia bajo el pedal y no necesitarla que al revés.... y vaya si se nota ir sobrado de potencia. Antes usaba...
Binding Posts & Terminals
Discover our range of speaker terminals, alone or mounted on a plate, for the design of your speakers or HiFi amplifiers.
  • Binding Posts
    Binding Posts
    Discover our range of speaker terminals (without mounting plate) for the design of your speakers or amplifiers.
  • Speaker terminals
    Speaker terminals
    Discover our range of speaker terminals mounted on plates or mounting brackets, for the design of your HiFi speakers.
