DAYTON AUDIO Double binding post spring loaded (pair)
4.5 / 5
Reference : 2925
16,90 €tax incl.
14,08 € tax excl.
Shipping date: 20-05-2025.
Nouvelle page 1
Dual-Ended Spring-Loaded Gold Terminal Pair
Finally a solution for getting wires in and out of cabinet sub-enclosures! These dual-ended push terminals will eliminate the need for messy caulking or having to solder inside a cabinet. Simply drill two 5/32" holes in your 3/4" walls (max 22mm), tighten the two halves of the posts together, strip your wires, and connect. Can also be used for many other applications, including main input terminals for car audio enclosures. Accepts up to 8-gauge bare wire, sold in red/black color coded pairs.
Mounting typeTo screw
ConnecticFemale
Max panel thickness (mm)22.0
Accepts Banana PlugsYes
ConnectorSpeaker terminal
2 reviews
Perfect!
Great product to get airtight, elegant connections for a subwoofer enclosure.
This review has been posted for DAYTON AUDIO Double binding post spring loaded (pair)
très bien
très facile à poser,seulement 2 petits trous à percer et visser les borniers
prévoir des petites rondelles en caoutchouc pour une parfaite isolation
