Binding Posts Pure Copper Ø4.5mm (Set x4)
These Viborg BP-614 terminal blocks ensure excellent conductivity thanks to their high-performance pure copper contacts. They accept conductors up to a diameter of 4.5mm and can be easily mounted with a locking screw. The terminal blocks also benefit from a modern design with an attractive carbon coating.
Product type | Binding posts |
Contacts material | Pure Copper |
Body materials | Carbon fiber POM Eutectic Copper alloy |
Insulation materials | Nylon (red/black rings) Polycarbonate (transparent ring) |
Mounting type | To screw |
Max. cable diameter | Ø4.5mm |
Body dimensions | Ø11.5 x 23.4mm |
Total length | 72mm |
Color | Carbon |
Quantity | Sold in sets of 4 |
Mounting type | To weld |
Connectic | Female |
Max panel thickness (mm) | N/A |
Accepts Banana Plugs | Yes |
Connector | Speaker terminal |
Contacts Material (Connector) | Copper |
Contacts Plating (Connector) | None |
