The Aoshida BLAD-S5 Bluetooth / FM receiver is a device featuring many high-quality components. It incorporates a Qualcomm QCC5125 Bluetooth receiver chip, an ES9038 DAC chip, as well as OPA1656 and a CS8406 SPDIF converter. The QCC5125 Bluetooth 5.1 receiver chip supports the following high-definition Bluetooth codecs: aptX, aptX Adaptive, aptX HD and LDAC (990kpbs - 24bit/96kHz). The ES9038 DAC chip and CS8406 SPDIF interface ensure digital-to-analog signal conversion for lossless wireless reception. Several analog and optical/SPDIF outputs are available: stereo RCA, coaxial SPDIF and Toslink optical. This device also offers the possibility of enjoying FM radio and USB DAC use via its USB-C input/power port. A large LCD display and a control interface with numerous buttons make for easy navigation, and display a wide range of information on the BLAD-S5's current playback and operating mode.
The QCC5125 Bluetooth receiver chip offers a new level of high-definition wireless reception, enabling the Aoshida BLAD-S5 to support the following high-definition codecs: aptX, aptX Adaptive, aptX HD and LDAC. In particular, LDAC enables wireless transmission superior to CD quality, with a sampling rate of up to 24bit 96kHz and a transmission speed of up to 990kpbs.
The Aoshida BLAD-S5 is more than just a Bluetooth receiver: it also features FM reception, so you can enjoy your favorite radio stations. FM transmission is also possible over a range of up to 20m.
Converts Bluetooth or USB digital streams to the BLAD-S5's analog RCA output.
Converts digital signals to the BLAD-S5's SPDIF coaxial and Toslink optical outputs.
These OPAs deliver excellent performance, with good dynamic range and low distortion, for quality sound reproduction at the BLAD-S5's outputs.
A large 2.4" LCD screen displays a wealth of information, making navigation and control of the BLAD-S5 simple and intuitive. The user experience is further enhanced by an IR remote control.
1 | IR receiver |
2 | Bluetooth antenna |
3 | Display |
4 | Control buttons |
5 | Stereo RCA output |
6 | SPDIF coaxial output |
7 | FM antenna connector |
8 | Toslink optical output |
9 | Bluetooth antenna connector |
10 | USB-C DAC input / Power port |
Product type | Bluetooth receiver / FM radio |
Bluetooth chip | QCC5125 |
DAC chip | ES9038 |
SPDIF interface | CS8406 |
OPAs | OPA1656 |
Inputs | 1x USB-C Bluetooth FM radio |
Outputs | 1x RCA analog stereo 1x Coaxial SPDIF 1x Optical Toslink FM radio |
Supported Bluetooth codecs | SBC, AAC, aptX, aptX Adaptative, aptX HD, LDAC |
Bluetooth range | 10m unobstructed |
Distorsion | 0.07% |
SNR | ≥ 98dB |
Input sensitivity | 0dBFS |
Output amplitude | 2.5Vrms |
Frequency response | 20Hz-20kHz (+/-1dB) |
IR Remote control |
Power supply | 5V/1A DC via USB-C (do NOT use fast-charge adapter) |
Dimensions | 89 x 125 x 54mm |
Gross weight | 0.78kg |
Color | Black |
Package | 1x Aoshida BLAD-S5 1x Bluetooth antenna 1x FM antenna 1x Toslink optical cable 1x USB-A to USB-C cable |
Input | USB |
Input | FM |
Input | Bluetooth |
Output | RCA |
Output | Modulation FM |
Output | Optical Toslink |
Output | Coaxial SPDIF |
DAC / ADC Chip | ES9038Q2M |
Color | Black |
Transmission / Reception protocol | Bluetooth |
Transmission / Reception protocol | UHF/RF |
Supported Bluetooth codecs | aptX HD |
Supported Bluetooth codecs | LDAC |
Supported Bluetooth codecs | SBC |
Supported Bluetooth codecs | aptX |
Supported Bluetooth codecs | aptX Adaptive |
Supported Bluetooth codecs | AAC |
