Bluetooth 4.2 Transmitter aptX Low Latency A2DP SBC Fast Stream Multipoint
The Avantree Audikast is a small Bluetooth 4.2 transmitter. It can therefore allow a previously Bluetooth-free device such as a TV, AV receiver, computer or audio source to enjoy it. This will allow you to stream your music directly from your source to your favorite Bluetooth headset.
The Audikast has Bluetooth 4.2 with an A2DP profile. This standard ensures excellent transmission speed and greater safety. In addition, the Bluetooth chip incorporates Qualcomm's aptX Low Latency technology, providing greater signal stability and greatly reducing latencies (< 40ms) for much better audio reproduction. This will allow you not only to enjoy your audio files but also if you wish to enjoy your movies or series via Bluetooth.
In addition, the Audikast's Bluetooth is Class 1 and benefits from an optimized antenna. As a result, the signal range is extended and you can use your Audikast up to 30m from it.
The Avantree Audiokast has three inputs. You will find there a Toslink Optical port, an AUX plug (3.5mm/RCA jack) and a Micro USB Audio These will allow you to connect the device to most of your peripherals.
In addition, you will be able to pair two Bluetooth headsets at the same time. So you can enjoy your music or your movies as a duo.
The transmitter offers an extremely simple, readable and ergonomic user interface. Indeed, LEDs on the top of the device will allow you to know the status of the device: whether it is in pairing mode, whether devices are connected to it or what type of codec is used. The two buttons, A and B, allow to control the connection of each headset independently of the other, and those in a very intuitive way.
For proper audio and image synchronization when playing back a video file, make sure your receiver (headphones / speakers) is aptX Low Latency compatible.
Bluetooth version | 4.2 |
Bluetooth profile | A2DP |
Audio codec | aptX Low Latency, aptX, Fast Stream, SBC |
Emitting distance | Up to 30m |
Inputs | USB Optical Aux (Jack 3.5mm / RCA) |
Multipoint | Yes - Up to 2 receiving devices connected at the same time |
Dimensions | 67 x 56 x 17mm |
Weight | 55g |
Color | Black |
Package | 1x Avantree Audikast 1x Male USB-A to Male Micro USB cable 1x male Jack 3.5mm to male Jack 3.5mm cable 1x male stereo RCA to female Jack 3.5mm cable 1x optical cable |
