This low-cost Bluetooth 5.0 receiver and transmitter will allow you to receive an audio stream from a smartphone or a tablet for example, or to broadcast your music wirelessly to a classic audio system or a headphone. In addition to the bi-directional Bluetooth, the device provides a Micro SD slot, a Toslink optical and coaxial input and a Jack 3.5mm input/output. It also features a display showing pairing information for easy and convenient use, as well as a volume control knob.
The receiver is identified by the name "C41"..
Product type | Bluetooth receiver and transmitter |
SPDIF DAC | 24bit / 192kHz |
Inputs | Bluetooth 5.0 1* Coaxial 1* Optical Toslink 1* Jack 3.5mm 1* Slot Micro SD |
Outputs | Bluetooth 5.0 1* Jack 3.5mm |
Supported protocols | A2DP AVRCP EDR HSP |
Supply voltage | 5VDC 1A |
Dimensions (L*P*H) | 104*91*25mm |
Color | Black |
Package | 1* Bluetooth receiver/transmitter 1* RCA to Jack 3.5mm cable 1* Jack 3.5mm cable 1* USB-A to USB-C cable 1* Optical cable |
Input | Bluetooth |
Input | Jack 3.5mm |
Input | Optical |
Input | Micro SD |
Input | SPDIF |
Output | Jack 3.5mm |
Output | Bluetooth |
DAC / ADC Chip | NC |
Max sampling rate | 192kHz |
Color | Black |
Networking | No |
Remote Control | No |
Transmission / Reception protocol | Bluetooth |
Supported Bluetooth codecs | N/A |
