Bluetooth 5.0 Receiver Transmitter Micro SD Jack 3.5mm Optical Coaxial
This low-cost Bluetooth 5.0 receiver and transmitter will allow you to receive an audio stream from a smartphone or a tablet for example, or to broadcast your music wirelessly to a classic audio system or a headphone.
Reference : 17282
24,90 €tax incl.
20,75 € tax excl.
Shipping date: 07-04-2026.
Bluetooth 5.0 Receiver / Transmitter
Récepteur / Émetteur Bluetooth 5.0
This low-cost Bluetooth 5.0 receiver and transmitter will allow you to receive an audio stream from a smartphone or a tablet for example, or to broadcast your music wirelessly to a classic audio system or a headphone. In addition to the bi-directional Bluetooth, the device provides a Micro SD slot, a Toslink optical and coaxial input and a Jack 3.5mm input/output. It also features a display showing pairing information for easy and convenient use, as well as a volume control knob.
The receiver is identified by the name "C41"..
Product typeBluetooth receiver and transmitter
SPDIF DAC24bit / 192kHz
InputsBluetooth 5.0
1* Coaxial
1* Optical Toslink
1* Jack 3.5mm
1* Slot Micro SD
OutputsBluetooth 5.0
1* Jack 3.5mm
Supported protocolsA2DP
AVRCP
EDR
HSP
Supply voltage5VDC 1A
Dimensions (L*P*H)104*91*25mm
Package1* Bluetooth receiver/transmitter
1* RCA to Jack 3.5mm cable
1* Jack 3.5mm cable
1* USB-A to USB-C cable
1* Optical cable
InputJack 3.5mm
InputMicro SD
OutputBluetooth
OutputJack 3.5mm
DAC / ADC ChipNC
Max sampling rate192kHz
Supported Bluetooth codecsN/A
This low-cost Bluetooth 5.0 receiver and transmitter will allow you to receive an audio stream from a smartphone or a tablet for example, or to...
