The FiiO BTR11 is a portable Bluetooth receiver headphone amplifier offering a qualitative wireless music listening experience. Its BES2700 Bluetooth receiver chip and independent headphone amplifier support the high-definition LDAC codec (24bit/96kHz), while its 3.5mm jack headphone output delivers substantial power output. It can deliver up to 2x 45mW @ 16 ohm and 2x 30mW @ 32 ohm. The BTR11 recharges via USB-C for up to 15h autonomy, making it perfect for everyday use or travel, for example.
The BES2700 Bluetooth receiver chip supports LDAC (24bit/96Khz) for the most reliable, stable and high-quality wireless transmission. It also enables two devices to be paired simultaneously, so you can quickly switch from one activity to another. An indicator LED also helps determine Bluetooth operation:
The FiiO BTR11 features a HT97220 headphone amplifier with an output power of up to 2x 45mW @ 16 ohm, capable of driving most low-impedance headphones and IEMs on the market and transforming them into wireless headphones.
The FiiO BT11's battery is capable of providing up to 15h of autonomy in the best conditions. It can be recharged via USB-C in just over an hour.
If it's disconnected, simply press the dedicated button for a quick reconnection.
A high-sensitivity microphone provides noise reduction during phone calls for clearer sound.
Not only can the BTR11 be used with IEMs, it can also transform your active speakers into Bluetooth speakers.
The BTR11's minimal size and weight make it easy to carry. In addition, it features a clip for attaching it to any item of clothing, so you're always free to move around.
Product type | Bluetooth receiver Headphone amplifier |
Bluetooth chip | BES2700 |
Headphone amplifier | HT97220 |
Input | Bluetooth 5.3 |
Output | 3.5mm headphone output |
Supported Bluetooth codecs | AAC, SBC, LDAC |
Output power | 2x 45mW @ 16ohm (THD+N=1%) 2x 30mW @ 16ohm (THD+N=1%) 2x 3mW @ 300ohm (THD+N=1%) |
Recommanded impedance | 8-100 ohm |
THD+N | < 0.008% (1kHz/-3dB@32Ω) |
Frequency response | 20Hz-20kHz : damping < 0.5dB 20Hz-45kHz : damping < 2.3dB |
Output impedance | ≤ 0.5Ω |
Channel separation | ≥ 76dB |
SNR | ≥ 101dB(A-weighted) |
Noise floor | ≤ 8uV (A-weighted) |
Volume control | Physical buttons |
LED indicator | |
Microphone | Built-in omnidirectional microphone supports Bluetooth phone calls |
Charging | 5V 1A via USB-C |
Battery capacity | 120mAh (lithium polymer) |
Battery autonomy | Up to 15h (AAC) / up to 8.5h (LDAC) |
Charging time | < 1.5h |
Color | Black |
Dimensions | 55 x 19 x 14.6mm (with clip) |
Weight | 13g |
Package | 1x FiiO BTR11 1x USB-A to USB-C cable |
Input | Bluetooth |
Output | Jack 3.5mm |
DAC / ADC Chip | BES2700 |
Color | Black |
Class | Class D / T |
Remote Control | No |
Transmission / Reception protocol | Bluetooth |
Supported Bluetooth codecs | LDAC |
Supported Bluetooth codecs | AAC |
Supported Bluetooth codecs | SBC |
