SHANLING BA1 Bluetooth 5.0 Receiver CSR8675 ES9218P aptX HD LDAC LHDC
Shanling's BA1 is a desktop Bluetooth 5.0 receiver. It is equipped with a CSR8675 Bluetooth receiver chip, an ESS ES9218P digital/analog conversion chip and is particularly easy and convenient to use.
4.0 / 5
Reference : 14963
159,00 €tax incl.
132,50 € tax excl.
Shanling BA1
Shanling BA1 Récepteur Bluetooth 5.0 CSR8675 ES9218P aptX HD LDAC LHDC
ESS ES9218P DAC
BA1's digital/analog conversion stage is equipped with an ESS ES9218P DAC chip. This one allows to provide a sound reproduction of quality, in particular thanks to a very low level of distortion.
CSR8675 & Bluetooth 5.0
Thanks to its Qualcomm CSR8675 chip, the BA1 supports Bluetooth 5.0, allowing you to stream your audio files simply and remotely. This chip supports high-resolution Bluetooth codecs such as HWA, aptX, aptX HD, aptX LL and LDAC, allowing you to enjoy your high-quality audio files.
Control app
Thanks to its dedicated control application, the Shanling BA1 offers advanced settings such as access to digital filters, equalizer and channel balance management.
Application Android Play Store Shanling Controller Application iOS App Store Shanling Controller
USB DAC Function
The Shanling BA1 can also connect directly to your computer via USB, in order to use it as an external USB DAC. Installation is extremely simple and requires no driver installation.
Outings for all needs
The BA1 benefits from 3 different outputs to adapt to each user's audio system. There is a 3.5mm headphone output, a stereo RCA output and a Toslink optical output.
Product typeBluetooth receiver
Bluetooth reception chipQualcomm CSR8675
DAC ChipESS ES9218P
Bluetooth version5.0
Supported Bluetooth codecsSBC, AAC, aptX, aptX HD, aptX LL, LDAC, LHDC
InputsBluetooth 5.0
1x USB-C
Output1x Jack 3.5mm headphone output
1x Stereo RCA
1x Optical Toslink
Supported sampling ratesBluetooth (LDAC / LHDC) : PCM up to 24bit 96kHz
USB DAC: PCM up to 16bit 48kHz
Transmission distance10m
Output levelHeadphone output: 1.41V
RCA : 2V
SNR-115dB
Channel separation73dB
THD0.0085%
Power supply5V 1A via USB-C (power supply not included)
Dimensions128 x 100 x 26mm
Weight205g
OutputOptical Toslink
OutputJack 3.5mm
DAC / ADC ChipES9218P
Supported Bluetooth codecsHWA LHDC
Supported Bluetooth codecsAAC
Supported Bluetooth codecsLDAC
Very beautiful, nice size and connect immeadiately.
This review has been posted for SHANLING BA1 Bluetooth 5.0 Receiver CSR8675 ES9218P aptX HD LDAC LHDC
Shanling's BA1 is a desktop Bluetooth 5.0 receiver. It is equipped with a CSR8675 Bluetooth receiver chip, an ESS ES9218P digital/analog...
