USB Dongle Bluetooth 5.2 Transmitter aptX / aptX HD / aptX LL / aptX Adaptive
This Bluetooth 5.2 USB transmitter dongle will allow you to broadcast audio streams wirelessly, from a computer for example, and in high quality, thanks to the use of a Qualcomm QCC3040 Bluetooth chip. This one is indeed compatible with the codecs of high resolution transmission aptX, aptX HD, aptX LL and aptX Adaptive, for a sound quality equivalent or even superior to that of the CD.
4.7 / 5
Reference : 16693
22,90 €tax incl.
19,08 € tax excl.
Shipping date: 07-04-2026.
Bluetooth 5.2 aptX / aptX HD / aptX LL / aptX Adaptive Transmitter Dongle
This Bluetooth 5.2 USB transmitter dongle allows you to stream audio wirelessly from a computer, for example, in high quality thanks to the use of a Qualcomm QCC3040 Bluetooth chip. It is compatible with aptX, aptX HD, aptX LL, and aptX Adaptive high-resolution transmission codecs, for sound quality equivalent to or even superior to that of a CD. A small LED on the dongle indicates the audio codec used by the dongle:
  • SBC: Solid blue
  • aptX: Solid cyan
  • aptX HD: Solid green
  • aptX LL: Solid white
  • aptX Adaptive: Solid orange
Product typeBluetooth transmitter dongle
Bluetooth version5.2
Range10m (maximum without obstacles)
Frequency range2.402-2.480GHz
Transmission protocolsA2DP
AVRCP
HFP
HSP
Supported bluetooth codecsSBC, aptX, aptX HD, aptX LL, aptX Adaptive
CompatibilityWindows XP / 7 / 8 / 10
Linux
Mac OS
Android
PS4 / PS5
Nintendo Switch
Number of devices that can be connected simultaneously1
Pairing indicatorAlternating red and blue
Plug and Play
OutputBluetooth
DAC / ADC ChipNC
Supported Bluetooth codecsaptX Adaptive
Supported Bluetooth codecsSBC
6 reviews
Satisfait de la livraison et du service Audiophonics mais appairage du dongle ne fonctionne pas
Je donne 3 étoiles à cet article pour la rapidité et le soin apportés à la livraison par Audiophonics.
En revanche, il m'est difficile de juger de la qualité du dongle lui-même, car je n'ai pas réussi à l'appairer avec aucun appareil après plus de 45 minutes d'essai, et ce avec trois appareils différents (Arcam rBlink, Pro-ject BT Box S2 HD et mon casque Sennheiser HDB 630). Ces trois appareils sont compatibles APTX.
J'ai changé à plusieurs reprises la distance entre le dongle et les appareils, sans succès : la lampe bleu/rouge du dongle clignote, mais l'appairage ne se réalise pas.
En revanche, celui-ci a bien été reconnu par Windows 11.
J’ai donc retourné, à regret, le dongle et demandé le remboursement de celui-ci considérant qu’il était défectueux.
This review has been posted for USB Dongle Bluetooth 5.2 Transmitter aptX / aptX HD / aptX LL / aptX Adaptive
Impeccable
Branché sur mon pc avec W10 je peux utiliser mon casque bluetooth à l'occasion et le son est très bon. Aucun drive à télécharger, ça marche direct.
A résolu mon problème de connexion bluetooth qui sautait entre pc et ampli, le tout avec une bien meilleure qualité sonore, une affaire. Je vois que le produit a été arrêté, j'espère qu'un équivalent sortira un jour si jamais celui-ci, qui pour l'instant fonctionne parfaitement, finit par lâcher.
Dongle
Ce dongle est performant sur W11. La connexion reste stable sur les 4 mètres qui le séparent de mon ampli.
Il privilégie le protocole APTX HD au maximum, car mon récepteur Bluetooth sur l'ampli ne peut pas accepter l'APTX Adaptive mais accepterait le LDAC.
AUDIOPHONICS devrait ajouter un dongle LDAC au catalogue .
Mais bon, mes FLAC restent très largement "écoutable"
Dongle Émetteur Bluetooth 5.2
Acheté pour utilisation arec une tablette sous W10 dont le Bluetooth a rendu l'âme. Reconnu directement et facile à connecter après quelques clignotements sur un D50s. Le son est plus que correct avec un léger assombrissement facile à corriger dans Foobar2000 (equaliser).
Excellent RQP.
This Bluetooth 5.2 USB transmitter dongle will allow you to broadcast audio streams wirelessly, from a computer for example, and in high quality,...
