XDUOO XQ50 PRO3 DAC Headphone Amplifier
The XDUOO XQ50 PRO3 is a DAC/headphone amplifier based on audiophile signal processing chips. A CS43131 chip converts a digital signal to analog and amplifies it for headphone output, while a CS8406 chip handles Bluetooth-to-optical/SPDIF signal processing.
Reference : 19783
115,00 €tax incl.
95,83 € tax excl.
Shipping date: 20-05-2025.
xDuoo XQ-50 PRO3 DAC Headphone Amplifier CS43131/CS8406 Bluetooth 5.1 aptX HD LDAC
XDUOO XQ50 PRO3 picture
The XDUOO XQ50 PRO3 is a DAC/headphone amplifier based on audiophile signal processing chips. A CS43131 chip converts a digital signal to analog and amplifies it for headphone output, while a CS8406 chip handles Bluetooth-to-optical/SPDIF signal processing. A Qualcomm QCC5125 Bluetooth receiver chip completes the package, enabling the xDuoo XQ-50 PRO3 to support standard Bluetooth codecs such as SBC and AAC, as well as high-definition codecs such as aptX, aptX LL, aptX HD and LDAC. In terms of interface, the XQ-50 PRO3 features a 360mW 6.35mm headphone output, a Toslink optical output, a coaxial SPDIF output and an RCA output. A USB-C 5V DC power port also enables the XQ-50 PRO3 to be used as a USB DAC. Additional benefits include a 1.3” color display and the ability to set various equalization parameters. This DAC/headphone amplifier is therefore an ideal solution for bringing Bluetooth connectivity to your existing Hi-Fi system and enjoying headphone listening.
xDuoo XQ-50 PRO3: Bluetooth 5.1
A Qualcomm QCC5125 Bluetooth 5.1 chip enables the XQ-50 PRO3 to support high-definition Bluetooth codecs: SBC, AAC, aptX, aptX LL, aptX HD and LDAC. The XQ-50 PRO3 is a Bluetooth gateway offering reliable, stable wireless transmission.
XDUOO XQ50 PRO3 Bluetooth functionality
XDUOO XQ50 PRO3 headphone amplification
xDuoo XQ-50 PRO3: comfortable headphone amplification
Thanks to its 6.35 mm headphone output and 365mW into 32 ohm output power, this device can drive many of the headphones and IEMs available on the market. In addition, this headphone output maintains a THD+N of 0.008% and an SNR of 115dB for clear, detailed sound reproduction.
xDuoo XQ50 PRO3: USB DAC function
The 5V DC USB power port also enables the XQ-50 PRO3 to be used as a USB DAC by connecting it to a computer, for example.
XDUOO XQ50 PRO3 USB DAC function
xDuoo XQ-50 PRO3: audiophile components
Photo of the CS43131 chip in the XDUOO XQ50 PRO3
Cirus Logic CS43131
Rather than relying entirely on its Bluetooth chip, the XQ50 PRO3 features an independent CS43131 DAC chip, ensuring high SNR and low distortion for clean, detailed reproduction.
Photo of the CS8604 chip in the XDUOO XQ50 PRO3
Cirus Logic CS8406
The CS8406 chip, meanwhile, is dedicated to converting the Bluetooth signal to the Toslink optical and SPDIF coaxial outputs for high-quality signal processing, enabling the use of a DAC or amplifier following the XQ50 PRO3 with complete confidence.
xDuoo XQ-50 PRO3: EQ and color display
The XQ-50 PRO3's additional strengths lie in the possibility of using equalization parameters and in the fact that it features a pleasant 1.3-inch color display on its front panel.
XDUOO XQ50 PRO3 EQ and display
Xduoo XQ-50 PRO3 overview
XDUOO XQ50 PRO3 overview
1Multifunction button
26.35mm headphone output
3Display
4Volume control
5RCA output
6SPDIF coaxial output
7Toslink optical output
85V DC USB-C power port / USB-C DAC input
9Bluetooth antenna
Technichal characteristics
Product typeDAC / Headphone amplifier
DAC / Headphone amplification chipCS43131
SPDIF interfaceCS8406
Bluetooth ChipQualcomm QCC5125
Input1x USB-C
Bluetooth
Output1x 3.5mm headphone output
1x RCA output
1x Coaxial output
1x Toslink optical output
Supported Bluetooth CodecsSBC, AAC, aptX, aptX LL, aptX HD, LDAC
Bluetooth range10m
6.35mm headphone output parameter
Output power360mW @ 32 ohm (1kHz)
THD+N0.008%
SNR115dB
Crosstalk88dB
Parameters for other outputs
THD+NRCA : 0.002%
Optical Toslink / Coaxial: 0.00087%
Output levelRCA : 2V
Optical Toslink / Coaxial: 0.05VP-P
Power supply5V DC 1A
Dimensions100 x 120 x 420 mm
Weight0.34kg
Package1x DAC Headphone amplifier XDUOO XQ50 PRO3
1x Bluetooth antenna
1x USB-C cable
1x 3.5mm to 6.35mm jack adapter
OutputOptical Toslink
OutputCoaxial SPDIF
OutputJack 6.35mm
DAC / ADC ChipCS43131
Max sampling rateNC
ColorGray
Supported Bluetooth codecsLDAC
Supported Bluetooth codecsSBC
Supported Bluetooth codecsaptX
Supported Bluetooth codecsAAC
XDUOO XQ-50 PRO3 DAC Headphone Amplifier CS43131 CS8406 Bluetooth 5.1 aptX HD LDAC
The XDUOO XQ50 PRO3 is a DAC/headphone amplifier based on audiophile signal processing chips. A CS43131 chip converts a digital signal to analog...
