RaspTouch RPI3 Black Chassis and Accessories Kit DIY
Reference : 14100
115,00 €tax incl.
95,83 € tax excl.
Caution : This version is designed for Raspberry Pi 3
If you plan to use a Raspberry Pi 4, use this version instead.
Available in a separate room, this CNC aluminum case allows you to create any kind of personal project: controllers, home automation devices, professional screens and many others. All these applications using the official Raspberry Pi parts supplied with.
Suite the success of our KickStarter on the RaspTouchand to your multiple requests, we now put on sale the different models on our site.
Find here the RaspTouch DIY Kit including all necessary accessories and modules, compatible with Raspberry Pi 3:
  • The black aluminum housing complete with the black support for the official Raspberry Pi screen
  • The push button
  • The Micro SD 25cm extension
  • The interconnection screen for the official Raspberry Pi screen 20cm
  • The HDMI 30cm
This aluminum casing was designed by Audiophonics to receive all components specific to the RaspTouch, that is to say an ES9023 DAC or an ES9018K2M DAC, as well as a Raspberry Pi 2 or Pi 3.
Specifications Case:
  • Housing 100% aluminumCNC machined (CNC machine)
  • Black Anodized / Chamfer
  • Dimensions: 200x95x230mm (Back panel: 175x55mm)
  • Weight: 840g
  • SD card slot
  • Port RJ45
  • HDMI port
  • USB-A x4 port
  • Port Jack DC 5.5 / 2.1mm x2
  • Analog stereo RCA output
  • Location button
  • Exclusive design
  • Useful internal dimensions of the housing (W x D x H) : 14 x 14 x 4.3cm
There are several other versions of the RaspTouch, here they are:
- RaspTouch DIY Kit Aluminum Chassis and Accessories with 7 "Touch Screen - Black Screen Support
- RaspTouch OpenSource Audiophile Reader DAC ES9023 / Raspberry Pi 3 - Display stand Black
- RaspTouch OpenSource DAC Reader ES9018K2M / Raspberry Pi 3 + RuneAudio - Display stand Black
RapsTouch logo officiel
The RaspTouch was developed in order to offer all HiFi enthusiasts a simple, elegant, affordable, and especially High Resolution compatible solution to play your favorite music.
In useRaspberry Pi, we offer our customers the option of choosing the software solution they want and that is best suited to their needs. Solutions such as Picore Player, Kodi, Raspbian and Rune Audio have been tested and are working with our RaspTouch.
Forcombine with your Raspberry, you have the choice between an ES9023 24bit / 192kHz DAC or a 32bit / 384kHz ES9018K2M DAC. No matter your preference, you will get a high-end converter with uncompromising performance.
Here is a technical diagram showing the universe where the RaspTouch can be placed:
RaspTouch lecteur opensource - Schéma technique
- Video of presentation of the RaspTouch complete under Raspberry Pi 3 + DAC sabre + Official screen 7 "-
MaterialMetal
