ELECAUDIO CS-361B Power Cable OCC PTFE 3x2.5mm² Double shielding Ø17mm
4.9 / 5
Reference : 7527
20,90 €tax incl.
17,42 € tax excl.
Shipping date: 07-04-2026.
The ELECAUDIO team has devised a mains cable capable of upsetting the established order as it implements materials and technologies usually reserved for products at much higher prices.
TheCS-361B is a mains cable developed according to a famous structure of Audiophile conductors namely the Litz wire, using strands of individually insulated copper wires it allows to control the skin effect of its structure.
Ainif the Phase and Neutral conductors of the CS-361B consist of 3 cores individually insulated with PTFE, these consisting of 6 strands of OFC copper surrounding an OCC core form a 2.5 mm² conductor overall.
These 3 conductors with a highly structured structure are encapsulated individually in PVC sheaths marked with a red / white / green color code. The bundles thus formed are themselves isolated from each other and kept in a distant order by means of a cotton lining which provides both suppleness and firmness to the assembly.
comesthen a first shield made from an aluminum strip, then a second one consisting of a braided copper braid preventing any EMI / RFI interference. Between these two lines of defense also comes a slip OFC copper drain wireant the cable from one end to the other to ensure linear earthing.
A thick silver-colored PVC protective sheath completes this work, and finishes making the CS-361B particularly resistant
Features:
  • 3 OFC Copper Conductors / OCC of Each Section 2.5mm²
  • PTFE insulation on main conductors
  • Exterior PVC Sheath of Forte Thickness Resistant to Wear and Shock
  • Cotton Trim
  • Double Shielding and Protection: Aluminum Sheath, Copper Braid Sheath, Copper Drain OFC
  • High-end Finish Color Silver Pearl
Specifications:
  • Main conductors :  3x (6x0.16mm OCC + 6x(6x0.16mm OFC) + PTFE)
  • Ground conductor : 126 x 0.16mm OFC
  • Diameter of Conductors + Single PVC Sheath: 5.50 mm
  • Total Cable Diameter: 17 mm
  • Bending radius : ~8cm
elecaudio cs361 b occ cable secteur
https://www.audiophonics.fr/images2/7527/7527_ELECAUDIO_CS361B_AUDIOPHILE_GRADE_POWER_CABLE_1.jpg
https://www.audiophonics.fr/images2/7527/7527_ELECAUDIO_CS361B_AUDIOPHILE_GRADE_POWER_CABLE_2.jpg
Example of embodiment:/ P>
https://www.audiophonics.fr/images2/7527/7527_ELECAUDIO_CS361B_AUDIOPHILE_GRADE_POWER_CABLE_4.jpg
Details of the structure:
https://www.audiophonics.fr/images2/7527/7527_ELECAUDIO_CS361B_AUDIOPHILE_GRADE_POWER_CABLE_3.jpg
Cable schematics
https://www.audiophonics.fr/images2/SCHEMA_PHASE.jpg
Diameter (mm)17.0
Number of conductors3
Insulation materialPTFE
ShieldingYes
Section (mm²)2.5
Ground / ShieldingYes
31 reviews
excellente finition sonorité plutôt douce
câble doux dans l'ensemble avec des basses un peu en retrait sur mon système, pas simple a monter, câble épais semi rigide, alimente ma barrette secteur actuellement, encore en rodage ! a voir dans une semaine ou deux si la sonorité se modifie
This review has been posted for ELECAUDIO CS-361B Power Cable OCC PTFE 3x2.5mm² Double shielding Ø17mm
The best purchase I've made in many years
I have heard many more expensive power cables and there has been an improvement in the sound, but this cable is to date the one that has given me the biggest improvement for the least money, in comparison to the Swedish SUPRA power cable which I have paid significantly more money for does not have the improvement in the sound at all, I immediately experienced an improvement in the bass, midrange and upper treble and 3D was fantastic, the only negative thing I can say is that it had a little emphasis in the upper treble, I could not hear that before... I do not hesitate to recommend this cable to others who may be skeptical about whether there is really anything to gain from power cables mounted cable with Oyaide plug P-046E & C-079. they were so fantastic that I compared it with the Power cable from LessLoss which costs 10 times the price, here LessLoss was a little better, but the tonal character was similar
regards Claus Olsen
 (4)
Topp Kabel
Ein Kabel ohne Kompromisse.
Konfektioniert mit Kupfer vergoldeten Steckern ein Muss.
Perfect!
Produit conforme à la description, livraison rapide et sûre. Merci pour une transaction réussie!
Excellente surprise... si on lui donne le temps de s'épanouir !
2 mètres de CS-361B exploités en entrée d'un BADA 6610 alimentant ma box, mon Node 2i (via carte PD Creativ + bloc Shanti) et mes Nuprimes Dac 9X & STA 9X).
Ce CS-361B est très déconcertant pour ne pas dire décevant durant les premiers instants, contribuant à une courbe de réponse "en cloche", très centrée "medium" avec un effet bouché et sans vie aux deux extrémités.
M'appuyant sur les précédents avis, et s'il commence à se réveiller entre 40 et 50 heures, j'ai laissé sous tension l'ensemble des maillons durant près de 100 heures (non sans streamer en boucle) avant d'envisager avis "sérieux".
Arrivé à ce terme, le résultat est fait d'ouverture, fluidité aération sans aucune dureté : c'est très convainquant !
Au-delà de sa très belle texture sur les voix (déjà mentionnée par ailleurs), mais pas que, je lui trouve surtout dans mon cas une homogénéité, pour ne pas dire une intégrité tonale sur l'ensemble du spectre : je constate qu'aucun segment du spectre particulier n'est favorisé au détriment d'un autre.
Guitariste possédant mon propre studio avec plusieurs (jolies) guitares (et leurs amplis), batterie et clavier, mes tympans m'invitent à rendre à ce câble secteur ce qui lui revient, c'est à dire sa capacité à éclairer (étirer ?) la restitution sans écraser la dynamique.
Au contraire, je trouve qu'il contribue très probablement à faire vivre les micro-détails avec subtilité sans rien dénaturer.
De telle sorte qu'il me donne la sensation d'être sinon immergé au milieu des musiciens, du moins au premier rang du concert en pouvant savourer l'effet tri-dimentionnel du spectacle musical proposé.
Surtout, il ne me donne pas envie de découper les décibels en quatre sur "mon aigue ceci, mon medium cela et mon grave machin" : cet ELECAUDIO CS-361B me donne tout simplement l'effet de contribuer à faire passer la musique avec sincérité.
Et, oui, comme le bon vin, il faut lui donner sa chance sans "sur-réagir" dès les première minutes...
Pour conclure concernant sa construction, je lui trouve bcp d'atouts techniques et sa mise en oeuvre, si elle demande un minimum de rigueur et de précaution, ne présente aucune difficulté.
Enfin, sa relative souplesse (ou raideur, c'est selon), ne pose pas de difficulté particulière dans son ergonomie.
Didier
 (4)
