OYAIDE EE / F-S2.6 V2 Power Cable 102 SSC Copper FEP Shielded 3x5.3mm² Ø14.5mm
Reference : 10006
105,00 €tax incl.
87,50 € tax excl.
Shipping date: 07-04-2026.
This new high-end mains cable is the result of the research of manufacturer Oyaide specializing in high-end drivers.
This cable is presented with a new generation Copper conductor called Virgin Copper 102 SSC composed of virgin copper only (not recycled).
afin to obtain strands to the surface perfectly smooth, the manufacturer used diamonds to smooth the surface.
HisThe IACS conductivity index is 102.3%.
The triple layer shielding protects the driver against all external disturbances.
It is ideal for in-wall wiring and can be used as an Hp cable.
Characteristics :
  • Conductor: Copper 102 SSC (3x 5.3mm² or 3x Ø 2.6mm)
  • FEP Insulation
  • Shielding 3 layers + Spiral copper wires (30x 0.18mm)
  • Coating: halogen-free polyurethane
  • V / A: 600V / 30A
  • Thermal operating limit: 75 ° C
  • Outside Diameter: 14.5mm
Diameter (mm)14.5
Length (m)Sold by length
Number of conductors3
Insulation materialFEP
ShieldingYes
Section (mm²)5.30
ConnectorN/A
Ground / ShieldingYes
10 reviews
Very nice cable superbe
I live in Hong Kong, this is a reliable in wall power cable, I brought 10 meters last year in Tokyo Japan as it is so stiff I have to fix it on the wall from my main power distributor to my HiFi power Cryo distributor box . Sound fantastic solid bass and full of details.
Very good products in Europe buy with Audiophonics.
This review has been posted for OYAIDE EE / F-S2.6 V2 Power Cable 102 SSC Copper FEP Shielded 3x5.3mm² Ø14.5mm
karamoke
Câble absolument exceptionnel! J'en ai trois sur mon gros système : prise murale-filtre secteur, ampli à tube AYON, DAC streamer Atoll ST300. Assemblés avec les meilleurs connecteurs Oyaide M1-F1 et P004-C004, le résultat est époustouflant.
Oyaide
Exceptional cable, I use it to power the phono pre, sound in the clear medium / high never tiring with a super detail that makes the difference, the bass is good but with a slightly fuller and more controlled bass it would have been the perfect cable, at least for the my plant. Cable that is worth much more than its price. It needs at least 100 hours of running in. Excellent purchase.
Tres bon cable
Un tres bon cable qui ajoute un niveau de détails et de profondeur de scène assez incroyable. Toutefois selon les autres éléments de votre système il risque d'apporter une coloration dans le haut du spectre, avec un système trop montant comme mon Primaluna avec KT88 des enceintes Sony SSA5, l'ensemble était trop agressif. Toutefois disposant d'un Atoll IN200 il était bien plus équilibré, et cerise sur le gâteau avec le changement de mon câble de modulation Canare Quad (recommandé par Audiophonic) , il atteint la perfection sur l'ensemble du spectre pour l'ensemble de mes enregistrements que je redécouvre effet de scène détails sans aucune coloration...
Excellent rapport qualité/prix
Je confirme les très bon avis des autres revues concernant les qualités musicales de ce cable : silence, qualité des timbres, dynamique, ouverture de la scène sonore...
Je l'ai monté avec des connecteurs Furutech de la gamme FI 50, très chers mais l'ensemble a surclassé sur mon ampli un NBS Black Label III dont le prix est sans comparaison.
Le seul bémol de ce câble est sa raideur. Il ne faut pas hésiter à resserrer plusieurs fois les connecteurs à plusieurs jours d'intervalle .
Une fois que le câble est monté et resserré plusieurs fois il n'y a plus qu'à écouter.
 (4)
