XANGSANE P-6008AG Power Cable
This Xangsane P-6008Ag power cable has an outer diameter of Ø18mm and features silver-plated OCC copper connectors for maximum connectivity. Each conductor is insulated by a PE and PVC sheath, and the whole is complemented by a silver-plated copper shield lined with aluminum foil, providing total protection against electromagnetic interference.
4.5 / 5
Reference : 20236
22,90 €tax incl.
19,08 € tax excl.
Shipping date: 07-04-2026.
Câble vendu au mètre
Xangsane P-6008Ag Power Cable Copper OCC Silver plated Double shielded 6x1.5mm²
XANGSANE P-6008Ag : Front view
This Xangsane P-6008Ag power cable has an outer diameter of Ø18mm and features silver-plated OCC copper conductors for maximum connectivity. Each conductor is insulated by a PE and PVC sheath, and the whole is complemented by a silver-plated copper shield lined with aluminum foil, providing total protection against electromagnetic interference.
Product typePower cable
ConductorsSilver-plated OCC copper
Cross-section6x1.5mm²
ShieldingSilver-plated copper
Aluminium foil
Conductor insulationPVC
PE
External sheathsPVC
Cable diameterØ18mm
ColorGreen
PackageSold by the metre
Diameter (mm)18.0
Number of conductors6
Insulation materialPE
Insulation materialPVC
ShieldingYes
Section (mm²)9.0
Ground / ShieldingYes
4 reviews
Definitely good
It's amazing, and for very little money.
Endless space, not so much energy in the midrange. Rich bass, smooth highs.
It will replace all my other cables (even the expensive ones).
The details are very clearly audible.
This review has been posted for XANGSANE P-6008AG Power Cable Silver Plated OCC Copper Double Shielded 6x1.5mm² Ø18mm
velka spokojnost
Dynamic and very detailed but excessively bright in midrange and highs
It’s a very good option for powered subwoofers, due to its powerful and very well controlled bass, and that is the only reason I gave it three stars. Otherwise, it is a disappointment. Overly bright in the midrange and high frequencies, in an unnatural and unpleasant way, even after long braking-in period. For general use, better go for the Elecaudio CS-361B which remains the emperor of the affordable power cords, being much more balanced, very detailed but in a natural and pleasing way and with phenomenal 3D imaging.
Rqp imbattable
Installé sur mon ampli , ce câble est neutre, et transparent. Alimente parfaitement mon ampli 3e audio. Également très bon pour les sources.
This Xangsane P-6008Ag power cable has an outer diameter of Ø18mm and features silver-plated OCC copper connectors for maximum...
