By buying this product you get 149 loyalty points
Gold Plated UP-OCC Copper Speaker Cable 17AWG Ø15mm 2m
The Neotech NES-3001 joins the brand's wide range of high-end speaker cables. Its unique design allows it to participate in the reproduction of both warm and deep sound, thanks in particular to the effective insulation of PTFE conductors.
The cable has no less than 16 insulated conductors: 6 red, 6 black and 4 transparent. Each conductor, made of UP-OCC single crystal Copper, has an outer diameter of Ø2.1mm and an inner diameter of Ø1.1mm for a cross-section of 17AWG (1.04mm²) per conductor for a total cross-section of 8AWG (8.37mm²). These individually insulated conductors are then braided around a PVC core and covered with a braided Nylon sheath.
These conductors are made of UP-OCC single crystal Copper, specially developed by Professor Ohno. This ensures an extremely high purity of 99.99998%. It thus offers maximum signal conductivity for high-precision sound reproduction.
The NES-3001 ends on either side with two gold plated and oxidation resistant forks, ensuring a firm hold of the connector to the terminals.
| Specifications | |
| Product type | Speaker cable |
| Length | 2m |
| Number of conductors | 16 |
| Conductors material | UP-OCC Copper |
| External diameter / conductor | Ø2.1mm |
| Internal diameter / conductor | Ø1.1mm |
| Section / conductor | 17AWG (1.04mm²) |
| Connectors | Spades |
| Connectors plating | Gold |
| Total external diameter | 15mm |
| Internal sheath | PVC |
| Conductors insulation | PTFE |
| External sheath | Braided Nylon |
| Delivered in pairs | Yes |
| Length (m) | 2.0 |
| Shielding | NC |
| Section (mm²) | 1.04 |
| Connector | Spade |
| Conductors Plating (Cable) | None |
