YARBO SP-3000A Speaker Cable OFHC Copper 2x3mm² Ø15.8mm
Reference : 8468
22,90 €tax incl.
19,08 € tax excl.
SP-3000A YARBO
Cable enceinte SP 3000A Yarbo
This two-conductor loudspeaker cable benefits from a durable and particularly slim construction. It's ideal for sound reinforcement projects where signal precision is paramount.
Each conductor is made up of multi-stranded OFCH pure copper wires surrounded by a silk braid, as well as thick single-stranded OFCH copper wires.
Yarbo 3000A SP
Cable enceinte haute fidélité
The whole system benefits from the mechanical cushioning of dense silica fiber, which protects the conductors from both crushing and twisting. What's more, each insulated conductor is encased in an individual polyethylene sheath that holds the structure securely in place, while significantly limiting the copper's exposure to oxidation and other common wear factors.
TypeSpeaker cable by the meter
Number of conductorsx2
Conductors diameterØ5mm
Section2x3mm²
MaterialsPure OFHC copper
QuantitySold by the meter
EndingsBare wires
Outer diameter15.8 mmØ
Diameter (mm)15.8
Length (m)Sold by length
Number of conductors2
Insulation materialPE
ShieldingNo
Section (mm²)3.00
Ground / ShieldingNo
