VIABLUE H-FLEX Digital Optical Toslink Cable 5m
Reference : 906
147,90 €tax incl.
123,25 € tax excl.
Toslink H-Flex ViaBlue cables are high-end optical audio cables that transmit digital signals using optical fibre technology. In this type of technology, electrical interference has no influence on the quality of the transmission. Toslink H-Flex cables provide a professional quality optical connection between high-end components such as amplifiers, CD/DVD decks, etc.
 The special fibre design for the waveguide used in Toslink H-Flex cables ensures maximum light source efficiency. These cables have a very high flexibility thanks to several machining processes used for the application of layers of insulation made of different materials, which allows very accentuated bending angles without increasing the attenuation rate. In the case of very large curvatures, the H-Flex optical fibre cable will transmit your data without any alteration.
The high quality waveguide is protected by a special flexible plastic compound. Another layer of very thin yet very hard plastic directly covers this compound to stabilize and fix the sensitive internal structure. Finally, a thick outer sheath protects these three inner layers from crushing and damage.
âToslink H-Flex cables are covered with a Cobra ViaBlue braid which provides additional external protection and an impressive external appearance. Equipped with Toslink H-Flex ViaBlue metal plugs, the ends of Toslink H-Flex cables are perfectly protected. The metal end caps up to the end guarantee stability over time and durable protection of the bare waveguide.
https://www.audiophonics.fr/images2/107/107_VIABLUEHFLEX.jpg
https://www.audiophonics.fr/images2/107/107_viablue_cable_toslink.jpg
Length (m)5.0
ShieldingNo
Section (mm²)N/A
ConnectorOptical Toslink
Conductors material (Cable)Optical Fiber
2 reviews
Super qualité
Ce câble optique a des connexions d'excellente qualité et la gaine du câble est solide ce qui est un atout pour parcourir 5 m au sol.
This review has been posted for VIABLUE H-FLEX Digital Optical Toslink Cable 5m
E.B. 1/01/15
J'avais 1 cable bas de gamme pour relier 1 Mac à 1 DAC M2tech
Je l'ai remplacer avec 1 cable viablue monté sur mesure par audiophonics (1 connecteur Mini toslink et 1 conducteur optique toslink à chaque extrémités).
Non seulement la réalisation est impeccable mais le résultat audio et véritablement d'une tout autre définition.
