SHANLING EC MINI Portable CD Player and DAP Sanyo 680 2x ES9219MQ Bluetooth 5.0 aptX LDAC 32bit 384kHz DSD256 MQA-CD Black
The Shanling EC Mini is a CD player and DAP combo that's as compact as it is versatile and high-performance. Its high-quality design allows you to enjoy your music in every detail, whether at home or on the move. What's more, the EC Mini boasts full connectivity, enabling it to function as a USB DAC or preamplifier, and even two-way Bluetooth 5.0 connectivity.
2.3 / 5
By buying this product you get 35 loyalty points
Reference : 18402
359,00 €tax incl.
299,17 € tax excl.
Shipping date: 08-05-2025.
Shanling EC Mini
Shanling EC Mini Portable CD Player and DAP Sanyo 680 2x ES9219MQ Bluetooth 5.0 aptX LDAC 32bit 384kHz DSD256 MQA-CD
Compact & battery-powered
The EC Mini sets a new trend for CD players, integrating a host of modern features in a compact format, for use both at home and on the move. You can enjoy your favorite CDs without the limitations of a conventional player.
Balanced architecture
Based on the use of a pair of ESS ES9219 DAC chips within a totally balanced architecture, Shanling's EC Mini is capable of delivering rich, faithful sound to bring out the best in your music. What's more, these chips support high-resolution audio streams as well as MQA-CD files.
HiFi components
The EC Mini's circuitry uses high-quality electronic components to enhance its sound reproduction. These include an LTA8092 amplifier, two RT6863 headphone amplifiers, low-noise, low-phase KDS oscillators and Panasonic and ELNA capacitors.
Simple controls
While CD playback can be controlled using the EC Mini's physical buttons, the device's 2.3" touchscreen offers additional control functions. Overall, the player is designed to provide excellent ergonomics for intuitive use and a very good user experience.
1Jack 3.5mm single-ended headphone output
2Jack 4.4mm balanced headphone output
3ON/OFF button
4Input selection
5Play Pause
6CD player
7Stop / Eject
8Volume -
9Volume +
10Bluetooth antenna
11USB-C charging port
12USB-C audio port
13Micro SD slot
14Pre-Out RCA
Comfortable autonomy
With its two built-in 18650 batteries for a total capacity of 6800mAh, the Shanling EC Mini provides excellent autonomy, enabling it to be used without an external power supply for up to 25 hours for playback from a Micro SD card, or up to 7.5 hours for CD playback. Charging is via a standard USB-C cable.
Philips CD player and Sanyo HD860 laser head
The Shanling EC Mini's built-in CD player is a high-performance Philips model, combined with a Sanyo HD860 laser head. This combination ensures accurate playback of CDs and MQA-CDs. What's more, the unit features a vibration-damping system to prevent stalling during playback.
Control application
The EC Mini can also be controlled from the free Eddict Player mobile app, available for Android and iOS. This makes remote control of your player extremely simple.
Ingenic X1000 controller
The EC Mini is based on the Ingenic X1000 platform, enabling the device to deliver a wide range of functions and fast data processing. This is combined with the proprietary MTouch system for smooth music playback.
Product typeCD player and DAP
InputsCD player
1x Micro SD slot
1x USB-C (USB DAC)
Bluetooth
Outputs1x Single-ended Jack 3.5mm headphone output
1x Balanced Jack 4.4mm headphone output
1x Pre-Out RCA
1x USB-C
Bluetooth
Bluetooth version5.0
Supported Bluetooth codecsReception: SBC, AAC, LDAC
Transmission: SBC, AAC, aptX, LDAC
Battery capacity6800mAh
Battery lifeMicro SD: up to 25h
CD player: up to 7.5h
TouchscreenLCD 2.33"
Supported file formats (Micro SD)DSD (.iso, .sdf, .dff) / DXD / APE / FLAC / WAV / AIFF / AIF / DTS / MP3 / WMA / AAC / OGG / ALAC / MP2 / M4A / AC3 / OPUS / TAK / CUE
DSD up to DSD256
DAC chips2x ES9219MQ
RCa output
Output level2.1Vrms
Frequency response20Hz - 40kHz (-0.1dBà
THD+N0.0005%
Channel separation110dB
Dynamic range114dB
SNR114dB
Jack 3.5mm output
Output power140mW @ 32Ω
Frequency response20Hz - 40kHz (-0.1dB)
THD+N0.0006%
Channel separation76dB
Dynamic range120dB
SNR120dB
Noise> 113dB
Impedance< 1Ω
Jack 4.4mm output
Output power248mW @ 32Ω
THD+N0.0005%
Channel separation115dB
Dynamic range123dB
SNR123dB
Noise> 110dB
Impedance< 1Ω
Dimensions250*205*52mm
Weight1.2kg
InputMicro SD
InputCD
OutputJack 4.4mm
OutputUSB
OutputJack 3.5mm
OutputBluetooth
DAC / ADC ChipES9219MQ/Q
Max sampling rateDSD256
Max sampling rate384kHz
Max sampling rateMQA
3 reviews
Shanling mini CD : une usine à gaz
Lecteur nomade Bluetooth bien construit et aux performances sonores excellentes. L’engin reste lourd et encombrant. Son gros défaut : de trop nombreux réglages et fonctions pas vraiment indispensables desservis par un ergonomie catastrophique. L’écran est minuscule et la navigation tactile hasardeuse entraine de très nombreuses prises de tête avant de pouvoir passer à l’écoute. Moins d’options et une petites télécommande basique aurait été bien plus fonctionnel. Prix finalement élevé pour un produit perfectible. Interface Eddict Player à l’avenant, c’est à dire inutilisable pour les non geeks.
This review has been posted for SHANLING EC MINI Portable CD Player and DAP Sanyo 680 2x ES9219MQ Bluetooth 5.0 aptX LDAC 32bit 384kHz DSD256 MQA-CD Black
Shanling confirme le défaut de la non prise en charge du gapless entre les pistes musicales.
Pas de corrections prévues pour le moment. Cette fonctionnalité n'est utilisable que pour les pistes sur microSD.
https://www.head-fi.org/threads/introducing-shanling-ec-mini-transportable-cd-player-dap.969879/post-17936483
Son précis et equilibré MAIS !...
Manuel très incomplet et surtout ne gère pas la lecture continue entre les morceaux lorsque les pistes sont prévues pour s'enchainer les unes à la suite des autres. Le lecteur, dans ce cas, rajoute en permanence quelques secondes de silence. Ennuyeux !
Espérons qu'un firmware corrige ce défaut. Plus ennuyeux encore, il n'est pas dit que ce défaut ne se trouve pas dans le modèle supérieur à 1300 euros tout de même. Attention donc !
The Shanling EC Mini is a CD player and DAP combo that's as compact as it is versatile and high-performance. Its high-quality design allows...
