SYITREN R300 CD Player on Battery Bluetooth 5.3 Black / Wood
The Syitren R300 is a small CD player with a nice retro design. Equipped with a Toslink optical output and a Jack 3.5mm headphone output, it will allow you to enjoy your CD collection at home as well as on the road. It also features Bluetooth 5.3 transmission capability, allowing it to automatically pair with Bluetooth headphones or speakers.
Reference : 17514
99,00 €tax incl.
82,50 € tax excl.
Shipping date: 09-04-2026.
Syitren R300
Syitren R300 Lecteur CD sur Batterie Bluetooth 5.3 Noir / Bois
The Syitren R300 is a small CD player with a nice retro design. Equipped with a Toslink optical output and a Jack 3.5mm headphone output, it will allow you to enjoy your CD collection at home as well as on the road. It also features Bluetooth 5.3 transmission capability, allowing it to automatically pair with Bluetooth headphones or speakers. A series of buttons on the right side of the R300 allow you to control CD playback and adjust the volume level on the headphone and Bluetooth output. A small screen at the bottom right displays information about the CD playback.
This CD player does not have a gapless function.
Product typeCD Player
Outputs1* Optical Toslink
1* Jack 3.5mm headphone output
Bluetooth 5.3
Supported CD formatsCD / CD-R / CD-RW
Supported file formatsMP3, WAV, WMA
Decoding chipAB5305UT
SNR80dB
Headphone output power11mW
Output level600mV
Battery2000mAh
Autonomy26h
Charging time~4h
Gapless Playback
Supply voltage5VDC 2A via USB-C (power adapter not included)
Dimensions (L*P*H)160*147.3*32.5mm
Weight400g
Body materialPlastic
ColorBlack / Wood
Package1* Syitren R300
1* USB-C to USB-A cable
1* Test CD
3 reviews
Nice surprise, plays gapless
I really like the design of this device, but I was reluctant to buy it due to the information that it doesn't have a gapless function, which is very important for me. It turned out that it does play continuous albums without adding gaps between the tracks, very nice surprise!
This review has been posted for SYITREN R300 CD Player on Battery Bluetooth 5.3 Black / Wood
Une très belle surprise
Encore une belle surprise de Chine, ce petit lecteur qui peut faire office de Discman avec sa batterie intégrée (léger mais un poil épais ceci dit pour une utilisation nomade) mais surtout de transport si vous possédez un bon DAC grâce à sa sortie optique. Je l'utilise branché à un Dac/Amp SMSL DO400 sur sa batterie intégrée et le résultat est pour moi aussi bon qu'avec des Transports CD bien plus onéreux que j'ai pu tester. Ce lecteur lit sans problème les CD gravés, et j'ai pu le tester également avec un CD de mon audiothèque qui est souvent récalcitrant avec mes autres platines/transports et à tendance à sauter sur certaines pistes. Aucun problème avec le R300, il a lu le CD sans un seul saut. Impressionnant. Voilà donc un moyen de s'offrir un Transport CD à un coût modique tout à fait performant. Et le look est très sympa et ne fait pas cheap du tout malgré la légèreté du lecteur. L'écran est petit mais lisible et les boutons de commande tout à fait réactifs (mais eux font un peu cheap).
Un grand remerciement à Audiophonics pour la préparation et expédition de la commande extrêmement rapide et à DPD pour la livraison tout aussi efficace, article commandé et reçu en moins de 24h !
Excellent rapport qualité/prix
Fonctionne sur batterie rechargeable avec un chargeur de mobile.
D'où faible bruit. Bien insérer le disque. Relié (optique) à un DAC (2XESS 2038). Résultat très bon. Excellent pour le prix.
The Syitren R300 is a small CD player with a nice retro design. Equipped with a Toslink optical output and a Jack 3.5mm headphone output, it will...
