Capacitors JANTZEN AUDIO Alumen Z-CAP are based on the Gold Silver Z-CAP series and benefit from a more ambitious assembly in terms of tonal neutrality.
This Aluminum - Polypropylene serie offers very balanced musicality without exaggerated brightness in the top of the audio spectrum (a common pitfall among high-end capacitors).
The series works with a dielectric that is thinner than usual. This prevents insulation fault memory, maintaining a rapid transfer of electrons from one winding to the other (very low resistance in series ESR). Capacitors Alumen Z-CAP then provide excellent charge speed, which achieves a harmonic precision worthy of the best in oil paper capacitors without having to worry about second-order harmonics degradation.
Formidable for filtering high-end dome tweeters (Scanspeak Illuminator, Revelator, Dynaudio Esotec, SB Acoustics Satori ... etc.), The Alumen Z-CAP are equally suitable for the tweeters Fountek NEO and Dayton ESS AMT or RADIA yet.
Also suitable for coupling in transistor amplifiers where the rated voltage is sufficient (100VDC).
Type | Capacitor |
Dielectric | Polyprolylène (PP) |
Capacitance | 0.47µF |
aluminum metallization | 99.99% |
DC Voltage | 100VDC 35VAC |
Tolerance | +/-3% |
Max temperature operation | 85 ° C |
Construction | Very low induction |
polarized capacitor | No |
very low series resistance (ESR) | Yes |
Diameter | 17mm |
Length | 44mm |
Weight | 24g |
Conditioning | Sold individually |
Tolerance (%) | 3.0 |
Capacitor capacitance | 0.47 |
Rated voltage (V) | 100.0 |
Capacitor type | Film capacitor |
Capacitor format | Axial |
