JANTZEN AUDIO ALUMEN Z-cap Condensateur 100VDC 10 µF
Reference : 13680
116,80 €tax incl.
97,33 € tax excl.
Shipping date: 15-09-2026.
JANTZEN AUDIO Alumen Z-cap
100VDC Capacitor 10 uF
jantzen-audio-alumen-z-cap-condensateur-
Capacitors JANTZEN AUDIO Alumen Z-CAP are based on the Gold Silver Z-CAP series and benefit from a more ambitious assembly in terms of tonal neutrality.
This Aluminum - Polypropylene serie offers very balanced musicality without exaggerated brightness in the top of the audio spectrum (a common pitfall among high-end capacitors).
The series works with a dielectric that is thinner than usual. This prevents insulation fault memory, maintaining a rapid transfer of electrons from one winding to the other (very low resistance in series ESR). Capacitors Alumen Z-CAP then provide excellent charge speed, which achieves a harmonic precision worthy of the best in oil paper capacitors without having to worry about second-order harmonics degradation.
Formidable for filtering high-end dome tweeters (Scanspeak Illuminator, Revelator, Dynaudio Esotec, SB Acoustics Satori ... etc.), The Alumen Z-CAP are equally suitable for the tweeters Fountek NEO and Dayton ESS AMT or RADIA yet.
Also suitable for coupling in transistor amplifiers where the rated voltage is sufficient (100VDC).
TypeCapacitor
DielectricPolyprolylène (PP)
Capacitance10µf
aluminum metallization99.99%
DC Voltage100VDC
Tolerance+/- 3%
Max temperature operation85 ° C
ConstructionVery low induction
polarized capacitorNo
very low series resistance (ESR)Yes
Diameter31mm
Length105mm
Weight8.5g
ConditioningSold individually
Tolerance (%)3
Capacitor capacitance (µF)10
Rated voltage (V)100
Capacitor typeFilm capacitor
Capacitor formatAxial
