ARYLIC A50+ Amplifier FDA STA326 WiFi DLNA UPnP Bluetooth 5.0 2x50W 4Ω
The Arylic A50+ is a versatile, high-performance FDA amplifier based on an STA326 chip and capable of developing 2x50W of power at 4Ω. It benefits from extensive connectivity, with Bluetooth 5.0 and WiFi reception, as well as full connectors panel. Indeed, we find a stereo RCA, Micro USB and Optical input, as well as a speaker and subwoofer output.
Reference : 15628
159,00 €tax incl.
132,50 € tax excl.
Shipping date: 13-05-2025.
Arylic A50+
Arylic A50+ Amplificateur FDA STA326 WiFi DLNA UPnP Bluetooth 5.0 2x50W 4Ω
A sound adapted to your listening
Whatever your gear or listening preferences, the A50+ can accommodate them. The ACPWorkbench DSP tool allows you to set different EQs for the left and right channels, as well as a variety of effects.
Subwoofer output
The A50+ benefits from a subwoofer output, allowing you to connect a subwoofer. This makes it possible to set up a 2.1 system for deep and powerful bass.
Multiroom & Control App
The A50+ can work with the 4Stream control app, available for free on Android and iOS. It allows you to remotely control the playback of your music but also to set up a multi-room system, controllable independently or by zones.
Application 4Stream Android
Application iOS 4Stream
Streaming
The Arylic A50+ is compatible with many streaming applications, such as Spotify, Tidal, Deezer or Qobuz, as well as with many web radios. So you can enjoy your music directly from your favorite music service.
Product typeAmplifier
Amplifier typeFDA
Amplification chipSTA326
InputsBluetooth 5.0
WiFi IEEE 802.11 b/g/n 2.4G
1x Micro USB
1x Stereo RCA line input
1x Ethernet RJ45
1x USB-A (USB Host)
1x Optical Toslink
outputsSpeaker terminal
1x Subwoofer output
Transmission protocolsAirPlay
DLNA
UPnP
Spotify Connect
Qplay
Supported sampling ratesPCM up to 24bit 192kHz
Frequency response20Hz-20kHz
THD+N0.03% @ 1kHz, 2x50W, 24V, 4Ω
Speakers impedance4-8Ω
Output power2x50W @ 4Ω, BTL, 21V
2x30W @ 8Ω, BTL, 24V
LED IndicatorWhite : WiFi
Blue : Bluetooth
Green : Entrée ligne
Red : USB
Yellow : PC
Purple : Optical
Application4Stream (iOS / Android)
Supply voltage12-24VDC 4.16A (power supply included)
Dimensions114.7 x 107.5 x 37mm
Weight500g
OPerating temperature0-40°C
Package1x Arylic A50+
1x RCA / Jack 3.5mm cable
1x RCA cable
1x Remote control
1x Screwdriver
1x Phœnix connector
1x Power supply 24VDC 4.16A
InputRJ45
InputWiFi
OutputSpeaker terminal
OutputSubwoofer
DAC / ADC ChipNC
Max sampling rate192kHz
ColorSilver
Channel2 (Stereo)
ClassFDA
Amplifier chipSTA326
Power (W)50.0
Remote ControlYes
Streaming services & Network protocolsAmazon Music
Streaming services & Network protocolsDLNA
Streaming services & Network protocolsDeezer
Streaming services & Network protocolsTidal
Streaming services & Network protocolsWeb radios
Streaming services & Network protocolsSpotify
Streaming services & Network protocolsQobuz
2 reviews
En application hifi, très étonnant !
reçu aujourd'hui et installé. Utilisé avec des dali oberon wall.
Niveau amplification, ça fonctionne en gros comme un fxaudio 802. donc ça fait le job comme un fda. Autrement dit, c'est propre, dynamique, ras. Pour ce type d'enceinte à rendement à peu près standard (85dB) avec une écoute à moins de 3m en appartement, ça suffit large. Je serai plus sceptique avec des très haut rendement (léger bruit de fond, aucun pb avec des enceintes à 85db, pas garanti avec des HD à 105db) ou alors pour remplir une pièce de 60m2 avec une écoute à 5m....on peut pas demander la lune à un ampli de 30W sur 8 ohm.
Donc bilan qualité du son, tant qu"on est sur son terrain de jeu c'est parfait.
......mais c'est sans compter sur son ENORME point fort ! ACPworkbench, pour 20€ de licence supplémentaire, on accède à quasi tous les paramètres de réglage du DSP intégré er là c'est un truc de fou. On peut tout faire et en particulier 4 équalisers paramétriques 10 bandes : 1 général, 1 gauche, 1 droite, 1 sortie subwoofer. On peut faire tous les réglages qu'on veut ou presque. Pour peut qu'on ait un peu de savoir faire, un micro, un logiciel de mesure (genre REW), et on peut régler ça aux micro poil. Pour le prix, c'est juste énorme et ça mache du tonnerre. En 10mn, j'ai corrigé le pic vers 200Hz causé par l'endroit ou sont installées les enceintes, coller un pass haut sur les dali et un pass bas sur le caisson maison (HP 22 dayton et ampli ncore250).
Pour l'appli de controle, simple fiable RAS, le pilotage à partir de deezer fonctionne très bien en airplay (attention aux spec, deezer n'est pas intégré à l'ampli, il passe via airplay ou bluetooth). Lecture du contenu d'un nas freebox via l'appli mconnecte sans pb avec protocole upnp.
Bilan final, à ce prix, avoir un ampli fort convenable, facilement connecté via 2-3 applications sur mobile et un dsp complet totalement paramétrable.....c'est Noël !
This review has been posted for ARYLIC A50+ Amplifier FDA STA326 WiFi DLNA UPnP Bluetooth 5.0 2x50W 4Ω
trés bon produit
Sa mise en route et son fonctionnement sont simples et faciles.
Dommage notice en Anglais !!!!!.
Audiophonics : Très satisfait de leur prestation .
The Arylic A50+ is a versatile, high-performance FDA amplifier based on an STA326 chip and capable of developing 2x50W of power at...
