ARYLIC H50 FDA Stereo Amplifier WiFi DLNA UPnP Bluetooth 5.2 2x50W 4 Ohm
The Arylic H50 amplifier is a compact, versatile and high-performance FDA stereo amplifier. It achieves an output power of up to 2x50W at 4Ω, and features quality components such as a Bluetooth 5.2 QCC3040 receiver/transmitter chip and an ESS ES9023P DAC chip, enabling it to support sampling rates up to PCM 24bit 192khz. It is also WiFi connected and compatible with a number of streaming services.
Reference : 18229
249,00 €tax incl.
207,50 € tax excl.
ARYLIC H50
FDA Stereo Amplifier WiFi DLNA UPnP Bluetooth 5.2 2x50W 4Ω
ARYLIC H50 FDA Stereo Amplifier WiFi DLNA UPnP Bluetooth 5.2 2x50W @ 4Ω
The Arylic H50 amplifier is a compact, versatile and high-performance FDA stereo amplifier. It achieves an output power of up to 2x50W into 4Ω, and features quality components such as a Bluetooth 5.2 QCC3040 receiver/transmitter chip and an ESS ES9023P DAC chip, enabling it to support sampling rates up to PCM 24bit 192khz. In addition to its Bluetooth 5.2 functionality, it is WiFi connected and compatible with a large number of streaming services. Arylic has even made its amplifier compatible with a control application, available on IOS and Android, called 4stream. Moreover, it features a wide range of connections, including the essentials, plus a subwoofer output, a phono input and an HDMI ARC input.
Wireless and multifunctional FDA stereo amplifier
The main strength of Acrilyc's H50 is its wireless connectivity. In fact, it works with streaming protocols such as Airplay 2, Alexa, Spotify connect, Tidal connect, DLNA UPnP and Qplay. It is also compatible with a large number of online streaming services: Spotify, Tidal, Deezer or Qobuz, Amazon music, Napster and more. It features a WiFi antenna and an RJ45 ethernet port. The Ethernet port lets you connect without using the 4Stream control application, and play your music directly from your smartphone.
Bluetooth 5.2
Thanks to a Qualcomm QCC3040 chip, the H50 is able to receive and transmit different Bluetooth codecs: SBC, ACC, aptX HD, aptx LL, AptX AD. Bluetooth functionality also enables you to pair 2 devices simultaneously, such as Bluetooth speakers or headphones, to share your music with friends and family.
ARYLIC H50 Amplificateur FDA Stéréo WiFi DLNA UPnP Bluetooth 5.2 2x50W @ 4Ω
2.1 home theater configuration
A subwoofer output on RCA connector lets you transform your 2.0 system into a 2.1 system with an active subwoofer for a more immersive listening experience. Coupled with the HDMI ARC input port, the H50 can be transformed into a small home theater amplifier. In addition, it's CEC-compatible, so you can control your TV's power and volume with a single remote control.
Multiroom and control app
The H50 can be operated with the 4Stream control app, available for free on Android and iOS. This allows you to remotely control your music playback, and also to set up a multiroom system, controllable independently or by zones. The control app also features a 10-band equalizer, so you can customize your listening experience to suit your preferences.
Phono input for turntables
Arylic has also equipped its H50 amplifier with a phono input so you can enjoy your vinyl collection. This phono input is compatible with MC and MM cell turntables.
Remote control
The H50 comes with a remote control that offers a wide range of functions. In addition to the traditional play/pause/previous/next and volume controls, you can select your source device and manage bass/treble EQ.
A wide range of connectors
1Bluetooth antenna
2DC power connector
3Speaker terminals
4Switch 4/8Ω load
5Phono input (Stereo RCA and GND)
6Stereo RCA input
7Subwoofer RCA output
8Optical Toslink input
9HDMI ARC input
10LAN RJ45 input
11USB-A input (U- Disk)
12USB-C input
13Reset button
14WiFi antenna
Product typeAmplifier
Amplifier typeFDA
DAC chipESS ES9023
Bluetooth chipQCC3040
Inputs1* USB-C (DAC USB 48kHz)
1* USB-A (U Disk)
1* LAN RJ45
1* HDMI ARC
1* Optical Toslink
1* RCA stereo line input (2 Vrms max.)
1* Phono input (MM/MC compatible)
Bluetooth
WiFi
Outputs1* Speaker terminals
1* RCA subwoofer output (3Vrms/250Hz)
Bluetooth (2 devices simultaneously)
Output power2x50W @4Ω (@ 24V)
2x 30W @8Ω (@ 24V)
2x50W @ 8Ω load at 24V (Boost)
Speakers impedance4-8
THD+N< 0.1% @ 1W 1kHz
SNR> 93 db @ max. power
Transmission protocolsAirplay 2, Alexa, Spotify connect, Tidal connect, DLNA UPnP and Qplay
Compatible streaming servicesSpotify, Tidal, Deezer, Qobuz, Napster, Pandora, Amazon Music, Internet radio, iHeartRadio, vTuner, Sound machine, Radio paradise, Calm radio, QQ music, QQ FM
WiFiIEEE802, 11 b/g/n 2.4g/5g
Ethernet100Mbps
Multizone functionWith 4Stream or Airplay 2
Screen2.23" OLED
Power supply24V DC 16A
Dimensions185*155*50mm
Weight901g
Package1* Arilyc H50
1* Bluetooth antenna
1* WiFi antenna
1* Remote control
1* AC adapter 24V 4.16A with DC power cable
InputPhono
InputHDMI ARC
InputRJ45
InputWiFi
OutputSpeaker terminal
OutputBluetooth
OutputSubwoofer
DAC / ADC ChipES9023
Max sampling rate192kHz
Channel2 (Stereo)
Channel2.1
ClassFDA
Amplifier chipN/A
Power (W)50.0
Remote ControlYes
Streaming services & Network protocolsAmazon Music
Streaming services & Network protocolsDLNA
Streaming services & Network protocolsSpotify Connect
Streaming services & Network protocolsDeezer
Streaming services & Network protocolsTidal
Streaming services & Network protocolsWeb radios
Streaming services & Network protocolsTidal Connect
Streaming services & Network protocolsQobuz
The Arylic H50 amplifier is a compact, versatile and high-performance FDA stereo amplifier. It achieves an output power of up to 2x50W at...
