By buying this product you get 59 loyalty points
The WiiM Amp Ultra is the culmination of a new generation of connected amplifiers, designed to meet the highest expectations of modern audiophiles and audio technology enthusiasts. With its meticulous design, remarkable power and network intelligence, this all-in-one device brilliantly combines high-performance amplifier, audiophile streamer and high-end digital-to-analog converter. Able to drive a wide variety of passive speakers with ease, it transforms your audio installation into an immersive, fluid, connected and upgradeable multiroom hi-fi system. Whether you're listening to high-resolution music, watching a movie or simply enjoying a sound experience perfectly calibrated to your space, the WiiM Amp Ultra is the technological and acoustic heart of your home audio environment.
The WiiM Amp Ultra's sleek, one-piece aluminum chassis is enhanced by a 3.5" color glass touchscreen. This interactive interface makes it easy to navigate between your sources, manage playlists and control playback, directly from the device or the WiiM Home mobile application.
Beyond its elegant design, the WiiM Amp Ultra contains cutting-edge audio technology. It's equipped with a robust Class D amplifier using two TI TPA3255 chips and TI OPA1612 PDUs, enabling it to deliver up to 2x 200W into 4Ω to drive a wide range of loudspeakers, from bookshelves to columns.
Sound quality is assured by a top-quality DAC, the ESS ES9039Q2M chip, capable of decoding high-resolution audio files up to 24-bit 192kHz. The result is crystal-clear sound reproduction, with deep, controlled bass, rich mids and detailed highs, offering a wide, immersive soundstage that brings your music to life.
To deliver outstanding sound quality, the WiiM Ultra Amp also features advanced Post-Filter Feedback (PFFB) technology, designed to dramatically reduce distortion, improve clarity and ensure consistent sound quality, regardless of speaker load. This PFFB technology dynamically compensates for these inconsistencies, promoting precise, balanced and natural sound reproduction. The result is a wide soundstage, incredible richness of detail and an extremely immersive musical experience.
The WiiM Amp Ultra benefits from a particularly efficient thermal management system, allowing the heat generated by the amplification to be dissipated. It uses copper heat pipes to transfer heat from the heating components. This heat is then routed to a large aluminum heatsink for efficient heat dissipation. All this is complemented by precision PID control, enabling real-time temperature regulation for optimum cooling and enhanced reliability.
To help you enjoy all your music in the best possible conditions, the WiiM Amp Ultra is equipped with the latest wireless technologies. It features WiFi 6 tri-band and Bluetooth 5.3 connectivity, with support for SBC and AAC codecs. So you can enjoy your music simply and in high quality.
With the WiiM Amp Ultra, you benefit from extensive compatibility with the most popular streaming services. So you can stream your music directly from Spotify, Amazon Music, TIDAL, Qobuz, Deezer, Pandora, iHeartRadio, TuneIn, Soundcloud and many more. What's more, if you prefer to use your own apps rather than WiiM integration, the Amp Ultra is also compatible with Chromecast, Alexa Cast, Spotify Connect, TIDAL Connect, Qobuz Connect, DLNA, SqueezeLite and Roon (certification pending).
The front panel of the WiiM Amp Ultra features a superb 3.5" glass touchscreen. This is combined with an ergonomic interface, capable of displaying album covers, meters and access to all the device's settings and navigation.
Thanks to its integrated RoomFit technology, the WiiM Amp Ultra is able to take acoustic measurements of your room, so you can adjust the sound reproduction of your system according to your listening environment and equipment.
Thanks to an advanced equalization system and a wide range of profiles, you can tailor your system's output to your personal taste. The WiiM Amp Ultra features 24 predefined EQ profiles, a 10-band graphic and parametric equalizer, independent EQ settings for each input, and subwoofer cutoff frequency control.
The WiiM Amp Ultra boasts particularly versatile connectivity, and will integrate easily with turntables, CD players and TV sets. What's more, it can stream to any WiiM or Bluetooth-compatible device.
The WiiM Home mobile app lets you take full control of your WiiM Amp Ultra: play music, adjust equalization, manage your multiroom setup, set alarms or update firmware, all simply from a smartphone or tablet.
The WiiM Voice Remote 2 also lets you control all WiiM Amp Ultra functions. It features a robust aluminum chassis, rechargeable battery and voice commands. What's more, some of these buttons can be configured to suit your needs.
Product type | Connected amplifier |
Inputs | 1x Stereo RCA 1x Optical Toslink 1x HDMI ARC (Dolby Digital 5.1 formats support) |
Outputs | Speaker binding post 1x USB-A (support up to 8 channels, UAC 2.0 compatible) 1x Subwoofer output (mono RCA) |
Network connectivity | Bluetooth 5.3 (supports bi-directional A2DP, AVRCP, HID and works with the WiiM voice-controlled remote control) WiFi 6 (upgradeable to WiFi 6E) Ethernet RJ45 (100Mbps) |
DAC chip | ESS ES9038Q2M |
Amplification chips | 2x TI TPAA3255 OPA TI OPA1612 |
Output power (THD 0.08%) | 2x 100W @ 8Ω 2x 200W @ 4Ω |
Amplification technology | Class D with PFFB (Post-Filter Feedback) technology |
THD+N | ≤ 0.005%, -106dB (A-wt) |
SNR | ≥ 120dB |
Dynamic range | ≥ 120dB |
Damping factor | 94 |
Frequency response | 20Hz - 20kHz ±0.5dB |
Impedance range | 2-8Ω |
Supported sampling rates | PCM up to 24bit 192kHz |
Equalizer (EQ) | 24 equalization profiles 10-band graphic and parametric equalizer Integrated acoustic correction with microphone |
Supported streaming protocols | WiiM Home app Chromecast audio Spotify Connect TIDAL Connect DLNA, LMS Roon Ready (certification in progress) |
Multiroom audio | Compatible with WiiM Home, Google Home and Alexa |
Touchscreen dimensions | 3.5" |
Color | Gray |
Dimensions (L x P x H) | 200 x 211 x 76.2mm |
Weight | 2.45kg |
Package | 1x WiiM Amp Ultra 1x Power cable 1x RCA cable 1x Optical cable 1x HDMI cable 1x WiiM Remote 2 remote control 4x Banana plugs |
Input | Bluetooth |
Input | WiFi |
Input | Optical |
Input | RJ45 |
Input | HDMI ARC |
Input | RCA |
Output | USB |
Output | Subwoofer |
Output | WiFi |
Output | Speaker terminal |
Output | Bluetooth |
DAC / ADC Chip | ES9039Q2M |
Max sampling rate | 192kHz |
Color | Gray |
Channel | 2.1 |
Channel | 2 (Stereo) |
Class | Class D / T |
Amplifier chip | TPA3255 |
Power (W) | 200.0 |
Remote Control | Yes |
Streaming services & Network protocols | Spotify Connect |
Streaming services & Network protocols | Spotify |
Streaming services & Network protocols | Roon / Roon Bridge / Roon Ready |
Streaming services & Network protocols | Qobuz |
Streaming services & Network protocols | Amazon Music |
Streaming services & Network protocols | DLNA |
Streaming services & Network protocols | Tidal Connect |
Streaming services & Network protocols | Deezer |
Streaming services & Network protocols | Chromecast |
Streaming services & Network protocols | Tidal |
Streaming services & Network protocols | Web radios |
