This XH 2.54mm female/female ribbon cable will allow you to make quick connections between two XH 2.54mm male connectors for your DIY projects. This takes advantage of copper conductors to ensure very good signal conductivity.
This 20cm cable is composed of 40 wires and has on one hand male XH connectors (40 connectors), and on the other hand stripped wires. This type of cable can be very useful in DIY assemblies, to connect different modules with XH subbases. Each wire is of course detachable.
This XH2.54mm cable has a 5 pin female connector on both sides. It ensures an excellent quality of signal transmission thanks to silver plated conductors.
This XH2.54mm cable has a 5 pin male connector on both sides. It ensures an excellent quality of signal transmission thanks to silver plated conductors.
