Simple , pratique et efficace pour du travail soigné , elle permet d'optimiser de façon directe et rapide les connexions enceintes /ampli. Indispensable !
Crimping tool for cable ends from 1.5 to 6mm²
Clamp designed to easily crimp your cable ends.
Crimping is a technique of connection that has been used for a long time and successfully in many technical fields.
The quality of contact is superior to that obtained by the traditional methods, the tip does not crush, and compresses the driver well.
In addition, it is much easier to make the fitting, as long as you work with the right tools.
| Max cable diameter (mm) | N/A |
| Section (mm²) | 5.00 |
| Section (mm²) | 3.00 |
| Section (mm²) | 5.50 |
| Section (mm²) | 6.00 |
| Section (mm²) | 4.00 |
| Section (mm²) | 3.50 |
| Section (mm²) | 2.5 |
| Section (mm²) | 4.50 |
| Section (mm²) | 2.00 |
| Section (mm²) | 1.5 |
| Contacts Material (Connector) | N/A |
| Contacts Plating (Connector) | N/A |
Average votes 5.0 / 5 7 reviews | Why write products reviews ? You can share your feelings about products and help other people by sharing your experience |
Damien M.
Jean-Pierre S.
Jean-Marc B.
Jean-Yves B.
