DAC Board for Raspberry Pi 2x ES9023 24bit 192kHz
This DAC HAT module will allow you to transform your Raspberry Pi into a real high quality audio system, without breaking the bank. It includes a balanced digital to analog conversion stage, equipped with two ESS ES9023 DAC chips, allowing it to read PCM audio streams up to 24bit 192kHz.
4.0 / 5
Reference : 16718
32,90 €tax incl.
27,42 € tax excl.
Shipping date: 13-05-2025.
Module DAC pour Raspberry Pi 2x ES9023 24bit 192kHz
This DAC HAT module will allow you to transform your Raspberry Pi into a real high quality audio system, without breaking the bank. It includes a balanced digital to analog conversion stage, equipped with two ESS ES9023 DAC chips, allowing it to read PCM audio streams up to 24bit 192kHz. The installation of the module is very simple and fast, since it is enough to connect it to the Raspberry Pi via the GPIO port. The audio output can be either stereo RCA or stereo 3.5mm jack. The module is also delivered with an IR remote control to control the playback remotely..
Product typeDAC board for Raspberry Pi
DAC Chip2x ES9023
InputsGPIO
Outputs1x Stereo RCA
1x Stereo Jack 3.5mm
CompatibilityRaspberry Pi 4B / 3B+ / 3B / 3A / 2B / Zero
DriverI2S driver / overlay : RPI DAC / ES9023 / Hifiberry DAC
PCB dimensions (without connectors)65.3 x 56.1mm
Mounting holes spacing58 x 49mm
Package1x DAC board
1x Remote control
Screws and spacers
InputGPIO
OutputJack 3.5mm
DAC / ADC ChipES9023
Max sampling rate192kHz
2 reviews
Bass for a bargain.
I'd almost forgotten what bass sounds like and feels like. Electronic music sound especially good. I think it's a massive improvement on the onboard sound from a Raspberry Pi 4. I can't do an A/B test easily because you have to disable the onboard audio which isn't difficult once you know what to do but it isn't easy to find out what to do if you're not a real nerd. Like the other review says there are zero instruction for this product. I'm still using (and want to continue using) Raspberry Pi OS. If anyone wants to know, this is what you need to do (maybe there are other ways but this worked for me) Open the terminal (the black box on the taskbar) and type sudo nano /boot/config.txt press "enter" then using the arrow keys find the line "#dtparam=i2s=on" and delete the #. Next find and delete the line "dtparam=audio=on" and replace with dtoverlay=hifiberry-dac Then find the line dtoverlay=vc4-kms-v3d and add ,noaudio (note the comma - no spaces). Finally press control and x (together) then "y" for yes to save the changes then reboot.
I have no complaints about the service from Audiophoniics. I picked it up from the post office a couple of days after ordering. I chose this DAC because it was the cheapest that has RCA outs and mini-jack for headphones. The RCAs aren't disabled when you plug headphones in (which suits me). The best slightly less than 40€ including shipping I've spent for a long time.
This review has been posted for DAC Board for Raspberry Pi 2x ES9023 24bit 192kHz
Son agréable
Monté sur un Pi 3 A+ sous moode player ce module a un son très agréable. Je n'ai pas de matériel de qualité suffisante pour en dire plus.
Il est livré avec une télécommande totalement inutile (et sans pile malgré une bandelette qui laisse croire le contraire). Pas envie d'acheter 3 piles bouton juste pour satisfaire ma curiosité.
Le point qui m'a fait retirer une étoile est qu'il n'y a absolument aucune documentation. On aurait pourtant bien aimé savoir comment piloter par logiciel les fonctionnalités que la télécommande laisse supposer. Ou tout au moins savoir quel pilote choisir dans la longue liste proposée par moode player.
This DAC HAT module will allow you to transform your Raspberry Pi into a real high quality audio system, without breaking the bank. It includes a...
