The DAC, preamplifier and headphone amplifier NFB-27.38 from Audio-GD takes the qualities of the NFB-27 and MASTER 9 by incorporating Non Feedback technology for high sound neutrality and advanced audio technologies.
KEY POINTS:
By buying this product you get 194 loyalty points
DAC / Headphone Preamplifier / Amplifier
This is the new version of the NFB-27, the NFB-27.38, with the qualities of the NFB-27 and MASTER 9. This version is the latest in the NFB family, which stands for "Non-Feedback" against reaction).
Non-Feedback is the technology used by Audio-GD so that it does not "color" the sound at the level of the electronics of the output stage, giving you a sound of professional neutrality.
This device has a DAC SABER ES9038pro supporting the signals up to 32bit / 384kHz and DSD in USB, all thanks to the new asynchronous interface AMANERO 384 combo of the manufacturer. In order to use the AMANERO correctly, here are the indications of Audio-GD as well as the download link of the driver: Amanero Combo 384 USB Interface.
The DAC preamplifier NFB27.38 also has a potentiometer with switched resistors of the highest quality on 100 steps.
The NFB-27.38 has 8 inputs: XLR / RCA x2 / USB / Coaxial / BNC /I2S via HDMI / Toslink optics, alongside 3 analog inputs: XLR / RCA / RCA. Including the DAC and Preamplifier outputs: XLR / RCA, as well as the 4 outputs Headphones: 1x XLR 4 PIN (ACSS) / 2x XLR 3 PIN / 1x 6.35mm stereo jack.
The 100% symmetrical and discreet design of this converter is backed by 5 groups of Class A power supplies. 24K Gold Plated RCA Plugs as well as Nover (UK) capacitors have been specially manufactured on specifications audio-GD.
The NFB-27.38, in addition to all the rest, has a TCXO Audio-GD internal clock directly integrated into the system significantly lowering the jitter, as well as internal wiring designed entirely of OCC copper.
The ACSS analog output stage, which is a feature of AUDIO GD, reduces the signal with only one buffer stage and an original Dale (USA) resistor. This shorter signal path allows the ES9038Pro to reproduce the highest level of detail and dynamics on ESS SABER DACs.
This NFB-27.38 is accompanied by its remote control metal, brushed aluminum finish. All the sobriety and class of Audio-GD stand out from this remote, as it is purified and functional. You will find 2 buttons to change your input sources, as well as 3 buttons to adjust the volume: Plus / Minus / Mute.
This SABER ES9038 conversion chipset built into the NFB-27.38 is one of the first generation 32bit converters capable of reading high-definition signals up to 32bit / 384kHz, not forgetting the DSD and PCM files. It is recognized as one of the most efficient and effective converters. You can find all its detailed documentation on the official ESS website: ES9038Pro - Reference 32-bit Audio DAC.
SNR | > 120dB |
Output Impedance | + 16dB (XLR) |
Output Level | Output DAC (1 Ohm) / Headphone Out (22V RMS) / Output Variable Preamplifier (10V RMS) / DAC Output Variable (2V RMS) / ACSS (2mA + 2mA) |
Headphone output (Balanced mode) | 1600mW (300Ohm) / 650mW (600Ohm) / 6000mW (50Ohm) / 4000mW (100Ohm) |
Input sensitivity | 0.5Vp-p (75 Ohm, Coaxial) / 19dBm (Optical) / USB1.1 / 2.0 (Full Speed, Class 2) |
Supported Operating Systems | Windows / OS X / Linux |
Supported sampling rates | USB up to 384kHz / Coaxial up to 192kHz / Optics up to 96kHz |
Frequency Response | 20Hz - 20kHz (<- 0 = "" 1db = "" 140khz = "" -3db = "" td = ""> |
Various | |
Consumption | 43W |
15kg | |
Housing material | 100% Aluminum |
Color | Black |
Dimensions | 430 x 430 x 93mm |
Accessories | 1x Power cable / 1x USB cable / 1x Remote control metal |
