I solved the problem with the installation with the usb plug, it was tested on you tube, and at the moment via spotify, great sound, I am pleasantly surprised, great device :)
By buying this product you get 23 loyalty points
This product has been replaced by the new version, the AUNE X8 XVIII BT MAGIC DAC FPGA Bluetooth aptX HD LDAC.
DAC FPGA Altera Max II 32bit 768kHz DSD512
The Aune X8 is a high-performance DAC, compatible with high-resolution files up to 32bit PCM 768kHz and DSD512. The conversion is done using an Altera Max II FPGA chip, specifically programmed by Aune to achieve high conversion quality. The device benefits from a complete range of connectors, with USB-B, Coaxial and Optical inputs. The audio stream can then be output to an RCA Pre-Out or RCA Line output.
A special feature of the Aune X8 is that the OPA sound can be easily interchanged with another model to adapt the sound reproduction to your listening experience. The underside of the device shows the OPA in place, mounted on a DIP8 bracket, and is delivered with an extraction clip and a storage box for your OPA.
The device also offers a series of 7 filters to adjust its sound signature more and more precisely.
The Altera Max II FPGA is the true heart of this Aune X8. Its program, developed and optimized by Aune, allows a particularly efficient conversion of digital streams.
Product type | DAC |
Conversion chip | FPGA Altera Max II |
USB Interface | XMOS U308 |
Inputs | 1x USB-B 1x Optical Toslink 1x Coaxial |
Outputs | 1x RCA Pre-Out 1x RCA Line out |
Supported sampling rates | USB : PCM up to 32bit 768kHz, DSD up to DSD512 Coaxial : PCM up to 24bit 384kHz, DSD DoP up to DoP128 Optique : PCM up to 24bit 192kHz, DSD DoP up to DoP64 |
Output level (line out) | 2Vrms |
Frequency response (line out) | 20Hz - 20kHz ±0.2dB |
SNR (line out) | 117dB |
THD+N (line out) | 0.0006% |
Housing material | Aluminum |
Dimensions | 145 x 171 x 45mm |
Color | Silver |
Package | 1x Aune X8 1x USB Cable 1x Power supply |
Input | SPDIF |
Input | USB |
Input | Optical |
Output | RCA |
DAC / ADC Chip | Altera MAX II |
Max sampling rate | DSD512 |
Max sampling rate | 768kHz |
Color | Silver |
Networking | No |
Remote Control | No |
Average votes 5.0 / 5 1 reviews | Why write products reviews ? You can share your feelings about products and help other people by sharing your experience |
Venčeslav D.
