Bluetooth 5.1 Receiver DAC Optical 24bit 96kHz / USB files Player
This small Bluetooth 5.1 receiver with integrated digital / analog converter will allow you to provide your audio system with a wireless reception capacity. Thus, it becomes possible, in an extremely simple way, to broadcast its music remotely, from a smartphone or a tablet for example.
Reference : 16867
35,90 €tax incl.
29,92 € tax excl.
Shipping date: 18-07-2025.
Récepteur Bluetooth 5.1 DAC Optique 24bit 96kHz
This small Bluetooth 5.1 receiver with integrated digital / analog converter will allow you to provide your audio system with a wireless reception capacity. Thus, it becomes possible, in an extremely simple way, to broadcast its music remotely, from a smartphone or a tablet for example. The device also provides an optical digital input Toslink and a USB-A port, allowing you to connect a USB key or an external hard drive. On the output side, we find stereo RCA and 3.5mm jack. The front panel of the device offers the possibility to control the volume of the device as well as to act directly on the playback of your music (play/pause, next, previous buttons).
Product typeBluetooth receiver with integrated DAC
InputsBluetooth 5.1
1x Optical Toslink
Outputs1x Stereo RCA
1x Jack 3.5mm
Frequency response10Hz - 20kHz
SNR> 110dB
THD+N< 0.02%
Bluetooth version5.1
Max reception distance (barrier-free)20m
Supported Bluetooth protocolsA2DP
AVRCP
Supported file formatsWAV, WMA, APE, FLAC, MP3
Supply voltage5VDC via USB-C
Housing materialABS
Package1x Bluetooth receiver
1x Bluetooth antenna
1x Power cable
1x Optical Toslink cable
1x Jack 3.5mm cable
OutputJack 3.5mm
DAC / ADC ChipNC
Max sampling rate96kHz
Remote ControlN/A
Supported Bluetooth codecsN/A
recepteur BT petit prix mais fait très bien le job
réception rapide.
correspond exactement à ce que je cherchais.
il m'a permis de transformer un vieil ampli en ampli acceptant le BT.
Qualité du son très bonne à ce que j'ai pu en juger (sur une autre chaine orientée HIFI).
Seul bémol, le niveau de son est faible par rapport à d'autres sources même quand on règle le niveau de volume au max sur le récepteur et sur la source BT. Mais ça ne détériore pas la qualité du son.
Il n'y a pas d’alimentation mais c'est indiqué dans la description.
Excellent rapport qualité prix.
This review has been posted for Bluetooth 5.1 Receiver DAC Optical 24bit 96kHz / USB files Player
This small Bluetooth 5.1 receiver with integrated digital / analog converter will allow you to provide your audio system with a wireless reception...
