Excellent ((petit)) Il lui manque juste une tél.
Comme ampli approchant les " AUDIOPHILE " Il a bien sa place.!..
DAC Headphone Amplifier Bluetooth 5.0 aptX ES9018 QCC3008 24Bit 192kHz Black
FX-Audio X6 MKII is an ideal solution for your compact, affordable and high-performance audio systems. It works both as a DAC with volume control and headpthone amplifierand offer multiple ways to connect to various devices (USB, Coaxial, Optique & Bluetooth).
Its analog and digital circuits use high quality components to achieve great audio reproduction in its price range. More specifically it works with an excellent ESS SABRE ES9018 conversion chip. and has a Bluetooth 5.0 QCC3008 interface which supports apt-X protocol.
At the heart of the device is a digital to analog conversion chip ES9018 with Hyperstream achitecture and frequency / time correction digital filters. This technology is particularly famous for its ability to limit distortion and jitter to respect your audio files down to the smallest detail.
In this configuration the X6 MKII offers a rich and detailed sound with PCM audio files up to 192kHz - 24bit.
Its analog stage is equiped with a OP275 operating amplifier (dual-bipolar / JFET) and a OP2134 (FET) offering a considerable headroom on its RCA output.
The headphone output uses a TPA6120 high fidelity amplifier with considerable power (940mW @16ohm)
capable of supporting models of headphones that are usually too demanding for standard audio equipment.
The DAC X6MKII has a USB input on a USB-B connector controlled by a CM6642 interface. The latter allows it to work directly with audio streams from your computer. This USB connector is not used for powering the X6-MKII, which will avoid most of the typical audio noise if your PC does not have an isolated USB interface.
The device also offers two S / PDIF inputs on Coaxial and Optical connector which open many possibilities for integration with your different digital audio sources (TV, game console, CD player ... ect.)
Finally, a QCC3008 interface allows the DAC X6-MKII to directly receive the audio stream from all your devices equipped with Bluetooth connectivity. Its reception circuit is in Bluetooth 5.0 standard and supports apt-X protocols for redoubled audio precision.
A short pression on the button located on the front panel is all it takes to switch input sources. Two set of LEDs keep the user informed of the active source as well as the current sampling rate.
Its RCA Stereo output with 2Vrms level is used to connect the DAC X6 MKII with a preamplifier, a power amplifier or active speakers.
A second 6.35mm jack connector located on the front of the device allows you to easily connect your headphones.
Product type | DAC with volume control Headphone amplifier |
Max sampling rate | 24bit 192kHz |
Output level | RCA : 2Vrms |
Output power (Headphone) | 940mW@16Ω 900mW@32Ω 700mW@64Ω 450mW@120Ω |
Inputs | USB-B Optical Coaxial Bluetooth |
Outputs | Stereo RCA Jack 6.35mm |
Power Supply | DC 12V 1A (included) |
Bluetooth | 5.0 with aptX support |
THD+N (Headphone) | 0.006% |
SNR (Headphone) | 112dB |
Frequency response (Headphone) | +0 / -0.5dB(20Hz-20kHz) |
Dimensions | 11.7 x 17.8 x 3.6cm |
Color | Black |
Package | 1x DAC-X6 MKII Black 1x Power adapter 12V |
Input | USB |
Input | Optical |
Input | SPDIF |
Input | Bluetooth |
Output | RCA |
Output | Jack 6.35mm |
DAC / ADC Chip | ES9018 |
Max sampling rate | 192kHz |
Color | Black |
Class | N/A |
Networking | No |
Remote Control | No |
Average votes 4.5 / 5 12 reviews | Why write products reviews ? You can share your feelings about products and help other people by sharing your experience |
Valéry H.
patrick a.
Eric B.
Michel L.
FRANCOIS G.
