FX-AUDIO DAC-X7 DAC AK4490 32Bit / 384kHz DSD XMOS CS8422 Black
Highly anticipated, the FX-AUDIO Dac X7 is a real concentration of technology that exploits the best components of the moment to achieve a rare sound clarity.
4.6 / 5
Reference : 12625
149,00 €tax incl.
124,17 € tax excl.
DAC X7, great analog converter by FX AUDIO
DAC X7 front view, digital screen, two headphones outuput (6.5 & 3.5) and volume knob
Highly anticipated, FX-AUDIO's X7 DAC is a real concentrate of technology that uses the best components of the moment to achieve a sound clarity and accuracy rarely achieved. From the point of view of its electronic construction, the DAC X7 is optimized for a very respectful conversion of the musical nuances in order to preserve the richness and the depth of the sound signal.
DAC X7 - advanced components
The DAC X7 with the AK4490EQ chip
The DAC X7 is based on the excellent converter AK449 and provides sound resolutions usually found only in advanced professional devices. It allows to enjoy each sound in its smallest detail with a level of distortion almost null. In addition, its signal-to-noise ratio is one of the best in the market with a score of 120 dB. Used in parallel with an XMOS chip, the X7 can take advantage of what the market is currently doing best in terms of 32-bit USB interfacing.
dac x7 digital screen
As powerful as it is versatile, the DAC X7 has all the necessary ports for easy integration into your Hi-Fi system. Toslink, Coaxial, USB & Micro-USB input & RCA output with two headphone outputs. A digital display on the front panel displays the essential parameters such as the active source as well as the sampling frequency, a very practical tool that will greatly facilitate the installation and handling of the device to arrive quickly to an optimal rendering.
The FX-AUDIO X7 has a very accessible volume knob on the front panel. In this, it stands out from the bulk of its direct competitors like the SMSL M6 that offer a similar level of performance and price range without having this option.
The Dac X7 is a must-have item that will easily find its place in any advanced audio installation.
FX-Audio DAC-X7 Review by Qobuz
" This DAC-X7 FX-Audio offers quality sound performance with fine and precise reproduction and uncommon decoding capabilities. "
Test FX-Audio DAC-X7 par Qobuz
Caracteristiques techniques
USB sample rate32bit / 384kHz
Coaxial / optical Sample rate24bit / 192kHz
DSD64 / 128 / 256
InputOptique, USB, Coaxiale, Micro USB, AUX
OutputVariable RCA / Jack 6.35mm & Jack 3.5mm
Impedance16-300Ω
Alimentation12V 1A
DACAK4490
USB InterfaceXMOS
S/PDIF ChipCS8422
Headphone amplifierTPA6120
Signal AmplifierOPA2604
Package Contents
1xDAC X7
1xUS Power cord / Wall adapt
1xUSB-A / USB-B cable 1.5m
OutputJack 3.5mm
OutputJack 6.35mm
DAC / ADC ChipAK4490
Max sampling rate384kHz
Max sampling rateDSD256
15 reviews
Bon rapport qualité/prix
Quelques réglages sont nécessaires pour le faire fonctionner avec Linux (Ubuntu) mais des blogs expliquent la démarches à suivre simplement (https://forum.ubuntu-fr.org/viewtopic.php?id=1477981). Produit à la hauteur de mes attentes. Associé à un ampli Cambridge Audio et à une paire d'enceinte Triangle BR02, c'est la petite touche finale idéale pour parfaire mon installation entrée de gamme sans me ruiner.
This review has been posted for FX-AUDIO DAC-X7 DAC AK4490 32Bit / 384kHz DSD XMOS CS8422 Black
Fiabilité !
Deuxième retour en SAV pour un problème de connecteur Jack cette fois.
Dommage, très bien positionné sur le plan performances / prix, la fiabilité semble un peu en retrait.
Néanmoins, le support Audiophonics est toujours aussi efficace, réparation et retour du produit sous garantie, sans discussion, merci à eux pour le sérieux de leur SAV, cela compte aussi dans l'achat d'un produit.
excellent rapport qualité prix
Utilisé au sortir de mon PC pour lecture de mes fichiers FLAC. Le son est bien sûr incomparable. L'appareil est un vrai plug & play, pas de pilote à installer. On branche le câble USB, on allume, et on écoute ! Un vrai plaisir.
Perfect
bluffant
Bluffant pour le prix! Aération , précision, présence remarquables . Je l'utilise à partir d'un aune S1 et avec un ampli à tubes 330b sur des enceintes haut rendement (98db)..je n'ai pas testé les entrées usb et optiques...A écouter impérativement sur alimentation régulée (celle d'audiophonics est excellente) ou encore mieux sur batterie ....de la très haute qualité pour un prix dérisoire!
Highly anticipated, the FX-AUDIO Dac X7 is a real concentration of technology that exploits the best components of the moment to achieve a rare...
