ORIGINAL AUDIO OPA-Q2.1SE DAC ES9038Q2M / Headphone Amplifier Bluetooth 5.0 LDAC AptX HD 32bit 768kHz DSD64
The Original Audio OPA-Q2.1SE is a headphone amplifier and DAC. It delivers great performance thanks to its careful design. Its various functions and its numerous inputs and outputs make it a very good all-rounder.
By buying this product you get 44 loyalty points
Reference : 17521
449,00 €tax incl.
374,17 € tax excl.
Last items in stock !
Shipping date: 07-04-2026.
ORIGINAL OPA-Q2.1SE DAC ES9038Q2M / Amplificateur Casque Bluetooth 5.0 LDAC AptX HD 32bit 768kHz DSD64
DAC ES9038Q2M & USB XMOS Interface
The digital / analog conversion stage of the OPA-Q2.1SE embeds a very efficient ES9038Q2M DAC chip, offering excellent performance for precise and detailed sound reproduction. This DAC is notably associated with an XMOS USB interface, allowing you to enjoy high-resolution audio streams up to PCM 32bit 768kHz and DSD64.
Bluetooth reception with QCC5125 chip
Behind its antenna, the OPA-Q2.1SE hides a QCC5125 Bluetooth receiver. This will allow you to broadcast your music remotely, directly from a connected smartphone for example. In addition, this chip supports high definition transmission codecs such as AAC, SBC, aptX, aptX HD and LDAC, allowing to reach excellent wireless sound quality.
Original Audio OPA-Q2.1 Amplificateur / Amplificateur Casque Discret / DAC AK4490 Bluetooth aptX-HD LDAC 2x50W 4Ω 32bit 384kHz DSD256
A rigorous design
All the circuits of the OPA-Q2.1SE demonstrate great rigor, both in the architecture itself and in the selection of components or assembly. Thus, there are fully symmetrical headphone amplification circuits ensuring a very low level of distortion. The headphone amplification section is also based on the use of discrete components.
Two high-end 1612A double AOPs also provide a filtering function to provide beautiful sound transparency. A specially designed analog audio processing module also reinforces this sound neutrality while providing a certain musicality.
Great versatility
The OPA-Q2.1SE demonstrates great versatility thanks to these different inputs and outputs. Indeed we find on the box a USB type C input, an optical input and a coaxial input in addition to bluetooth.
Moreover, at the output level there are a 6.35mm Jack output, a 4.4mm balanced jack output, and also a balanced XLR 4 pins headphone output. On the other side there is a balanced XLR stereo output and an RCA stereo output allowing you to connect the OPA-Q2.1SE to an amplifier or active speakers.
A robust and modern frame
All components are housed in a sturdy CNC machined aluminum housing. In addition, this frame has a sober but modern aesthetic that will fit into many HiFi systems.
1Display
2Output Jack 6.35mm
3Output Balanced Jack 4.4mm
4Output balanced XLR 4 Pins
5Volume / Press selection
6Power button
7Power plug
8Bluetooth Input
9USB-C Input
10Optical Input
11Coaxial Input
12Output Stereo RCA
13Output Stereo XLR
Tecnical characteristics
Product typeDAC
Headphone Amplifier
InputsBluetooth 5.0
1x USB-C
1x Coaxial
1x Optical
Outputs1x Jack 4.4mm balanced
1x Jack 6.35 unbalanced
1x Headphone output XLR 4 pins balanced
1x stereo RCA
1x Stereo XLR
AOP2x double AOP 1612A
DAC ChipES9038Q2M
USB InterfaceXMOS
USB CompatibilityWindows 7/8/8.1/10/11 (with driver)
Mac OSX10.6 and more
Linux
Android
Bluetooth Chip QCC5125
Amp GainLow Gain 0dB
High Gain 10dB
Dynamic RangeBalanced headphone outputs : 126dB
Unbalanced headphone output : 124dB
Stereo XLR/RCA output : 123dB
Headphone amplifier output power2x  2.6W 16
2x 1.3W @ 32
Bluetooth specificationsSBC, AAC, aptX, aptX LL, aptX HD, LDAC
SNR126dB Balanced headphone outputs
124 dB Unbalanced headphone output
123dB Stereo XLR/RCA output
THD + NXLR/RCA : 0.0001% (-120dB)
Headphone outputs :  0.00015% (-116dB)
Power consumption <24W
Dimensions248 x 248 x 70mm
Weight5.5kg
Frame materialAluminium
ColorSilver
Package1x OPA-Q2.1SE
1x Power cable
1x Remote control
1x USB-A to USB-C cable
OutputJack 4.4mm
OutputJack 6.35mm
DAC / ADC ChipES9038Q2M
Max sampling rateDSD64
Max sampling rate768kHz
ColorSilver
ClassN/A
Remote ControlYes
The Original Audio OPA-Q2.1SE is a headphone amplifier and DAC. It delivers great performance thanks to its careful design. Its various functions...
